Hello,
what is the best and quickest way to turn a sequence into a simple clip element? I'm working on a bumper sequence for a series of video features.
Currently, I'm doing video,audio mixdown, then group clips. If there's a better way, that would be awesome.
Thanks!
Ervz Tia | Video ProductionsWM Communications, Asia-Pacific | Philippines
Sounds like you found the best way by using video / audio mixdown,
I can't think of another way.
Are you then grouping because you want to use the clips like a multicamera edit ??
Thanks. I'm doing mixdown-grouping to simply make them manageable and clean on the timeline.
I'm just wondering if there's a simpler command/trick in doing this.
tikboy:Thanks. I'm doing mixdown-grouping to simply make them manageable and clean on the timeline. I'm just wondering if there's a simpler command/trick in doing this.
