Latest post Fri, Nov 8 2019 1:24 AM by Mondo. 8 replies.
Page 1 of 1 (9 items)
  • Wed, May 25 2011 5:53 PM
    • anomaly_7
    • Joined on Fri, May 12 2006
    • New York
    • Posts 107
    • Points 1,400
    Exporting with an Alpha Channel
    Hey All,
    I have been trying to export using an alpha channel. The original source had an alpha, I can see the alpha when I step into the clip. However, something weird happens in the export. The job called for color correcting certain clips that contained alpha channels, so I color corrected the clips and set them up to export. My client now says the clips do not have the alpha. I exported them as such - animation, millions+, 720x486 - but when I bring them back into Avid MC to make sure they have the alpha, the alpha is no longer there...
    Am I missing something? Is it because of the color correction? Any help would be greatly appreciated.
    Sean
    2.5 Ghz Intel Core 2 Duo Macbook Pro, 4GB Ram. Mac OS X Leopard 10.5.5. Avid MC 3.1.2. [view my complete system specs]
  • Wed, May 25 2011 9:14 PM In reply to
    • rebusfilm
    • Malmo, Sweden
    • Posts 313
    • Points 3,950
    Re: Exporting with an Alpha Channel
    You can't export clips with alpha in Media Composer.
    A workaround is to export the fill and alpha channel as separate Quicktimes and then combine them after the export.
    Avid Media Composer 2020.4 | Mac Pro 7,1 | 16 core | 192 GB RAM | Radeon Pro Vega II | QNAP TVS-872XT | Decklink 4k Mini Monitor | Sony PVM-A250 OLED [view my complete system specs]
    Jorgen Persson
  • Thu, Sep 19 2013 6:34 PM In reply to
    • JSHEE
    • Joined on Thu, Sep 19 2013
    • Posts 1
    • Points 5
    I'm assuming this is still true in MC 7.02 as several tests have failed.
    Are there any new workarounds developed for this issue besides using AE?  Can AVID FX marry a key and fill?
    Thanks.
  • Mon, Mar 14 2016 12:16 PM In reply to
    • Pipa
    • Joined on Mon, Mar 14 2016
    • Posts 2
    • Points 20
    Hi anomaly_7,
    you can export video using alpha channel following this steps:
    Export
    Export Settings "Untitled" and click on "Options"
    Then it opens Export Settings:
    Export as Quicktime Movie.
    Mark "Use marks", "Use selected tracks" and "Include Inactive audio tracks".
    Mark Custom and click on the button "Format Options". It opens a new tab of settings.
    In Video Settings you have to go to settings, and then in "Compression Type" clic on "Animation".
    After, in "Compressor" click on "Millions of colors", and 100% quality.  Click on "Accept".
    And that's it!!!
    Hope this helped you!!
    Pipa
  • Wed, Jul 20 2016 9:09 PM In reply to
    • MACKLFUEL
    • Joined on Mon, Nov 15 2010
    • Posts 10
    • Points 120
    Sort of works  I exported and re imported and it shows it has an alpha channel but am not able to see video layer underneath it, Any ideas??
  • Wed, Jul 20 2016 9:33 PM In reply to
    MC is still not capable of exporting movies with alpha channels.
    While an alpha channel may get exported, it will probably be solid white and nothing will be keyable.
    It's been a long-standing request, but thus far has not happened.
  • Fri, Jul 22 2016 12:21 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,640
    MACKLFUEL:
    As the first reply said fill and matte as separate exports is the only way or you could load them into AvidFX if you have it and export the clips there - that does support proper alpha channel export although the built in export interface on RED/AvidFX is an absolute dog.
    John
  • Thu, Nov 7 2019 1:40 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,267
    • Points 15,230
    Kevin Klimek:
    I would need to create a DXV3 video with Alpha, for use with Resolume. I guess there is no simple workflow to accomplish that from MC (on PC) ?
    MC 20.10 (+Symphony)/BCC2019 12.5.2; BlackMagic Ultrastudio Mini Monitor+Recorder (11.6); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz - 32 GB RAM;... [view my complete system specs]
  • Fri, Nov 8 2019 1:24 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,640
    i think the only option is to export a separate matte channel.
    John
