Latest post Wed, Jul 6 2011 7:10 AM by Pat Horridge. 14 replies.
Page 1 of 1 (15 items)
  • Sat, May 21 2011 8:10 PM
    • jonleach
    • Posts 15
    • Points 175
    Mac Error -43 (File not Found)
    Hi All
    Sorry for the second post
    I keep getting the message "Mac Error -43 (File Not found)
    It just appears now and then and I am not doing anything in particular it is very annoying I thought that upgrading to 5.52 from 5.5 might clear it but does not.
    I only get it on this machine and not on others when using the same media files a little help
    Cheers
    Jon
    OSX 10.6.7
    MC 5.5.2
    Macpro 4,1
    Memory 8Gb
    MC 5.5.2
    Mac Pro
    Mac OS X 10.6.7
    Processor 2*2.26 GHz Quad-Core Intel Xeon
    Memory 8Gb 1066MHz DDR3
    HDD 4TB over 4 Drives
    Quicktime7.6.6
  • Sat, May 21 2011 8:19 PM In reply to
    Re: Mac Error -43 (File not Found)
    Jon:
    Be advised that 10.6.7 is not yet qualified for Media Composer. That could be the reason. More details at the Version Matrix. Check your Quicktime version too.
  • Sat, May 21 2011 11:59 PM In reply to
    • jonleach
    • Posts 15
    • Points 175
    Thanks for that I just rolled back to 10.6.6 and guess what 5 mins in and up it popped again aghhhh
    MC 5.5.2
    Mac Pro
    Mac OS X 10.6.7
    Quicktime7.6.6
  • Sun, May 22 2011 12:06 AM In reply to
    And you can't discern any kind of pattern in your workflow that triggers it? Like parking on the same clip in the timeline?
  • Sun, May 22 2011 1:51 AM In reply to
    • jonleach
    • Posts 15
    • Points 175
    No it is very odd different projects different formats and media on differnt drives it would be helpful to be able to find out what -43 actually means its a bit cryptic.
    P.S. only started after upgrading to 5.5  mc 4 was fine
    Jon
    MC 5.5.2
    Mac Pro
    Mac OS X 10.6.7
    Quicktime7.6.6
  • Sun, May 22 2011 3:31 AM In reply to
    • curiosity
    • Boulder, CO
    • Posts 845
    • Points 10,735
    -43 is an "unexpected end of file" error. Which usually means it went looking for a file and found random garbage instead. This can mean one of two probable things: the file it is looking for is corrupted (or the hard drive's catalog is), or the file system is wonky (like FAT 32 or a networked drive).
    We've had this problem come up a number of times when working with our Editshare system (a Linux box) trying to write to Windows formatted network partitions. The solution for us was to not use Apple's network system to write to Windows drives but to buy DAVE (which solved all of our issues).
    i7-6950(x99), 64GB, Win 10, GTX 1080ti iMac 2020 128GB RAM, 5700XT [view my complete system specs]
  • Sun, May 22 2011 8:02 PM In reply to
    • jonleach
    • Posts 15
    • Points 175
    Hi Thanks for that one tried DAVE but still the same so made the machine stand alone with no network and bang there it is again
    aghhhh
    MC 5.5.2
    Mac Pro
    Mac OS X 10.6.7
    Quicktime7.6.6
  • Sun, May 22 2011 8:04 PM In reply to
    • jonleach
    • Posts 15
    • Points 175
    Hi Thanks for that got the demo version of DAVE and had a try but still the same so tried making the Machine a Stand alone removed all networking and Bang Still there aghhh
    Jon
    MC 5.5.2
    Mac Pro
    Mac OS X 10.6.7
    Quicktime7.6.6
  • Sun, May 22 2011 10:44 PM In reply to
    • Dr.DOG
    • Joined on Mon, Feb 26 2007
    • Praha, CZ
    • Posts 95
    • Points 1,275
    Are you using TimeCapsule or TimeMachine disk connected to AirPort?
    G5 dualcore 2.3GHz, 3.5GB RAM, OSX.4.7, Mojo SDI, MC 2.64 G3 333 MHz, 640 MB RAM, OS 8.6, MC 9000 [view my complete system specs]
     Started on MC 5.12 NuBus
  • Sun, May 22 2011 11:30 PM In reply to
    • jonleach
    • Posts 15
    • Points 175
    Ahh good point will turn it off
    MC 5.5.2
    Mac Pro
    Mac OS X 10.6.7
    Quicktime7.6.6
  • Mon, May 23 2011 11:47 PM In reply to
    • jonleach
    • Posts 15
    • Points 175
    Nope was off
    MC 5.5.2
    Mac Pro
    Mac OS X 10.6.7
    Quicktime7.6.6
  • Tue, Jul 5 2011 7:00 AM In reply to
    • tzidore
    • Joined on Wed, Jun 1 2011
    • Posts 6
    • Points 75
    Hello there!
    I get the error using TimeMachine. I thought I was smart backing up the Media Composer folders using TimeMachine. Does anyone know if there is a workaround?
  • Tue, Jul 5 2011 5:42 PM In reply to
    • hbrock
    • Bainbridge Island, WA
    • Posts 5,569
    • Points 64,855
      Moderator: MCA Mac
    Exclude the disk or folder from the Time Machine preferences.
  • Wed, Jul 6 2011 7:03 AM In reply to
    • tzidore
    • Posts 6
    • Points 75
    I know that is the solution, but it would be so easy if I could backup the mediacomposer shared folder through TimeMachine, isn't that possible at all?
  • Wed, Jul 6 2011 7:10 AM In reply to
    The problem is Time Machine runs in the background and when it sees changes it will grab a file while it copies it. If MC needs that file it can't get it at that momment and an error occurs.
    Don;t use any automated backup system for MC application or user files. Use best practice and do regular saves and make copies of projects to external media at the end of each session.
