Sadly no update. Avid have given up and said that I need to do a clean OS install. The joy. =/ If that doesn't help, nothing will. I have another set of instructions given to me by support that have worked a few times. Also tedious though... Think a few paths down here was incorrect but easy enough to figure out i think. Let me know if not.
1. Open Applications > Media Composer 2. Save copies of your Avid Projects, Avid Attic, and Avid Users folders to your desktop 3. If you have any AVX plug-ins in the AVX plug-ins folder, save them too. You can also save any Marquee titles you may have. 4. Open Applications > Avid Uninstallers. Run the Media Composer Uninstaller 5. When that’s done, quit the installer application and open Applications. 6. Delete the Media Composer folder if it’s still there. Also delete any Dongle folders that may exist in Mac HD > Applications > Utilities 7. Open Mac HD > Library > Application Support and delete the Avid folder and Digi folder if they’re there 8. Open Mac HD > System > Library > Extensions and delete anything that starts with Avid 9. Open Mac HD > Applications > Utilities > Disk Utility and select First Aid 10. Verify Permissions and then Repair Permissions on the Mac HD. I would do this twice. 11. Restart the computer 12. You can now run the installer and install Avid Media Composer
Don't thonk this will get resolved until they find the dev of this that can shed some light on what's happening.
NEO aka Henrik Cednert.
cto | compositor
Filmlance International
Some of you might have the nitris/mojo Vs. Win 10 problem.
Avid sometimes doesn't see the boxes after system startup.
Solution:
When you get the "OS Error" and avid shuts down, go into device manager, disable mojo/nitris & re-enable.
Thanks Lukas
It works for me, but it is very anoying but it works for now.
hopefully AVID wil adress this problem.
Maybe it has somthing to do with the way win10 is starting up ??
Frank Blauenfeldt: I have the same problem as NEO (Henrik) but his guide does't work for me. Do you have any update on this issue ? NitrixDX will not initilize, so MC comming up with "OS_Error" and MC is shutting down. I allso getting it work on the first boot-up after a clean install of AVID MC, but from the second time and forward I get this "OS_Error" message. Please help if you can :-)
I have encontered this before and if you're on windows 10, do the following:
Problem solved.
When I was disabling the "Turn on fast startup"
Windows is slowingdown the startup proces, Nitris now can connect in time.
Thank you :-)
