Latest post Thu, Mar 10 2011 9:45 PM by gabocaba. 2 replies.
  • Thu, Mar 10 2011 8:41 PM
    • gabocaba
    • Joined on Thu, Oct 15 2009
    • Buenos Aires, Argentina
    • Posts 41
    • Points 590
    Play Source and Record monitors at the same time?
    Hello. That's my question. Can it be done?
    Actually what I needed it for was to try some sound clips that have a series of different sounds within those clips, and I needed to see wich ones work better on my sequence. So I wanted to leave the sequence in a constant playback, like the play in-to-out option, but WHILE I listen to the differents sounds in my clip, So I can mark which ones could work better.
    I'm not sure if this is something I can do with multicamera (I think not from what I've been reading, although I still don't have a clear grasp of how does the multicamera tool work)
    Thanks again
    i7 930 - windows 7 ultimate 64 - quadro fx1800 - 6gb ram [view my complete system specs]
  • Thu, Mar 10 2011 8:59 PM In reply to
    • Kristina
    • Joined on Sun, Nov 28 2010
    • Germany
    • Posts 463
    • Points 5,620
    Re: Play Source and Record monitors at the same time?
    In mc itself AVID is only able to do play or something else, not both ;-)
    I would suggest you, playing your timeline in loop as you mentioned and opening an external mediaplayer like for listening to your audioclips.
    Best regards,
    Kristina
    several z800 and xw8600 Nitris DX, MC v.5.5.3, Win XP Prof SP3, ISIS-5000 16TB with Force 10 Switch 10Gig, several MOG S1010 ingest servers, several EVS... [view my complete system specs]
  • Thu, Mar 10 2011 9:45 PM In reply to
    • gabocaba
    • Posts 41
    • Points 590
    Oh... ok. I'll have to make some workaround like that... although I cannot add locators or markers that way. But it'll have to do. A shame though.
    Many thanks for your quick response.
    bye
