Latest post Tue, Jan 4 2011 10:24 AM by mjolnarn. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Jan 4 2011 3:59 AM
    How to Import m2t at Lower Resolution?
    How to Import m2t at Lower Resolution (MC3 & MC5)?
    I can only see these choices (see image)
    Ervz Tia | Video Productions
  • Tue, Jan 4 2011 4:51 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: How to Import m2t at Lower Resolution?
    Your project settings seems to be full raster, are you sure that your m2t file also is full raster and not thin raster.
    If you switch settings to thin raster ( 1440 x 1080 ) you will get more import options
    Tomas
  • Tue, Jan 4 2011 6:32 AM In reply to
    Thanks. I tried changing but only 'Standard' raster gives me mulitple option for import, others are single/fixed.
    Here's the source clip info (according to MPEG StreamClip):
    Stream: 00_0032_2010-09-09_112422.M2T
    Type: MPEG transport stream
    Bit Rate: 25.21 Mbps
    Video Tracks:
    2064 MPEG-2, 1440 × 1080, 16:9, 29.97 fps, 25.00 Mbps, upper field first
    Audio Tracks:
    2068 MP2 stereo, 48 kHz, 384 kbps
  • Tue, Jan 4 2011 6:58 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Yes, that is standard thinraster hdv, just select hdv from the pulldown menu
    Tomas
  • Tue, Jan 4 2011 7:14 AM In reply to
    Yes, that's what I meant, sorry. When I choose HDV (or others), there are no other import resolution choices.
    I also tried changing the project format to DV/NTSC but it seems Avid ignores and still imports it as full resolution 1080/60i.
    Is this a correct off-line procedure? ...Am I even doing it right?
  • Tue, Jan 4 2011 10:24 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    You should have an option named hdv 1080 into that pull down list, as you only are having one thinraster codec somethings seems not to be correct with your install of MC 3.
    What version are you using?
    Is it very important for you to work with long gop, the first thing I do myself is to convert my long gop media to DNxHD ?
    Tomas
