Latest post Sat, Sep 4 2010 5:23 PM by lalondejv. 3 replies.
  • Fri, Sep 3 2010 5:25 PM
    • lalondejv
    • Joined on Wed, Jul 14 2010
    • Posts 9
    • Points 105
    Can't export AAF under 2GB
    Wasn't even sure how to search for this one.
    I have a sequence 45 minutes long with 10 tracks of audio. I realize that such length is too long for a single AAF. In the past I'm broken it up into 2 chunks and it worked fine. Now, however, I try exporting an AAF of a 10 minute section and I get a prompt that it's over the 2GB file size limit. What's more confusing, it that I was able to export 2 seperate sections (each around 7 minutes), each ending up at 300mb. But when exporting both sections as one, it goes over the 2GB limit. How can this be?
    I'm so very confused. Thanks in advance to all help.
    Jason
    Filed under: ,
  • Fri, Sep 3 2010 8:33 PM In reply to
    Re: Can't export AAF under 2GB
    I have no idea, but a suggestion, why not export A1A2 as one aaf and see how that goes, then move on to the next tracks. Combining them will be easier for the sound post than cutting it in pieces...
    i9-10980XE, ASUS PRIME X299-A II, 64GB, Win 10 Pro [view my complete system specs]
  • Fri, Sep 3 2010 10:25 PM In reply to
    Are you exporting Video with any of these?
    Are you consolidating before exporting
    FWIW I have not had problems with audio only 90 minute 20 audio tracks AAF as one export
  • Sat, Sep 4 2010 5:23 PM In reply to
    • lalondejv
    • Posts 9
    • Points 105
    thanks guys,
    The post facility prefers sections of all tracks as opposed to entire single tracks. They say it's easier for them.
    We are not exporting video. We tried both before and after consolidatig the sequence. Same problem both times.
