Latest post Thu, Aug 4 2022 6:05 AM by CBMEDIA. 13 replies.
Page 1 of 1 (14 items)
  • Sun, Jun 27 2010 6:28 PM
    • zayzay
    • Joined on Thu, Mar 12 2009
    • Spring Valley, NY
    • Posts 44
    • Points 550
    Exception: Cannot quick import a mixed resolution QuickTime movie.
    I've just done a clean install of Media Composer 5.
    So far I love it!
    I just tried to import a quicktime animation file I made in After Effects, and it fails.
    It says, "An unexpected error occurred while importing the Quicktime Audio Tracks.  The imported audio tracks may be unusable.  Would you like to continue the import?"
    I enter "continue" and it fails.
    It gives me this error in the console, "Exception: Cannot quick import a mixed resolution QuickTime movie."
    Does anyone know why this is happening.  Its a quicktime video file with no audio. It plays fine in Quicktime 7.6.6.
    any help would be greatly appreciated.
    Zay Zay
    Avid Media Composer 8.9.2 with Symphony Option, Aja Kona 4, Dell Precision T7910, Dual Intel Xeon CPU - E5-2663 2.8GHz, Windows 10 Professional 64-Bit... [view my complete system specs]
  • Sun, Jun 27 2010 11:52 PM In reply to
    Re: Exception: Cannot quick import a mixed resolution QuickTime movie.
    Zay Zay:
    What parameters are you using when you render out your After Effects composition for export?
  • Tue, Jun 29 2010 5:06 PM In reply to
    • zayzay
    • Spring Valley, NY
    • Posts 44
    • Points 550
    They are Quicktime Animation Files on the "Best" setting.
    Lower Field First ast this is 1080i.
    Channels: RGB
    I also tried a quicktime with the Avid DNxHD Codec.
    Color Levels: 709
    Alfa: Uncompressed
    Resolution 1080i/59.94 DNxHD 145 8-bit
    It won't impoort any video files. Only audio files.
    Any ideas?
  • Tue, Jun 29 2010 7:36 PM In reply to
    Believe it or not, check the free space on the drive you are importing to.  I have seen the "mixed resolution" message when the import drive was too full.
    I didn't say Avid errors made sense!
  • Tue, Jun 29 2010 7:58 PM In reply to
    • zayzay
    • Spring Valley, NY
    • Posts 44
    • Points 550
    LOL!!!
    Actually, the drive has plenty of space. I have @ 1TB left.
    Any other thoughts?
  • Tue, Aug 3 2010 2:57 PM In reply to
    • zayzay
    • Spring Valley, NY
    • Posts 44
    • Points 550
    Bump
  • Tue, Aug 3 2010 6:01 PM In reply to
    • jadakin
    • Joined on Wed, Jul 14 2010
    • Posts 168
    • Points 2,030
    For After Effects is there video?  What video is it.  It's possible that if the codec that what used inside AE is different from the Codec used to make the movie could be the conflict.  Also, if you have QT Pro or Sorenson try encoding it to H.264 and AMA link then transcode?
    HPZ800 2.9 ghz dual quad, 4TB raid 0, MX02 Mini, MC5.0.3, 12gb Ram, Nvidia FX4800, trying out WD External 3.0 USB 1TB, W7 prof [view my complete system specs]
  • Wed, May 23 2012 7:00 PM In reply to
    • JasonByfield
    • Joined on Tue, Oct 13 2009
    • Kirkland, WA
    • Posts 11
    • Points 160
    Kevin Klimek:
    This worked for me!  Thanks so much... and Avid, your engineers are crap at implimenting clear and concise error messages.
    OS X Snow Leopard (10.6.8), Mojo DX w/ Media Composer 6.0 fibre channel to Unity MediaNetwork 5.1.3, QuickTime 7.6.6, Mid 2010 MacPro:2 x 2.93 GHz 6-Core... [view my complete system specs]
  • Wed, May 23 2012 7:05 PM In reply to
    JasonByfield:
    Please keep in mind that members and participants here on these boards are for the most part NOT AVID EMPLOYEES unless you see a badge under their name identifying them as such. Members here are your peers, other editors from all over the world helping each other. If you want to provide direct feedback to Avid employees, you are best contacting them from one of the offices in this list. Thank you for your cooperation.
    And by the way, I agree with your assessment about error messages.
  • Wed, May 23 2012 11:13 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,446
    • Points 98,375
    The trouble with error messages is that they can often become triggered by events other than those they were originally designed to trap.  They are also often written primarily as debugging aids to the programmer(s) and can mean little to anyone else.
    That said, Avid's error messages have been known to set new benchmarks for obscurity!
  • Wed, May 23 2012 11:39 PM In reply to
    • JasonByfield
    • Kirkland, WA
    • Posts 11
    • Points 160
    I dunno... Final Cut Pro's dreaded "General Error" is pretty bad.
  • Thu, May 24 2012 2:48 AM In reply to
    • jwrl
    • Posts 8,446
    • Points 98,375
    JasonByfield:
    No, that's just saying "there's a problem and I have no idea what it is."  That's pretty clear - not helpful, but clear.  At least it's honest.
    Hey, what am I doing defending FCP?
  • Fri, Jun 24 2022 3:23 AM In reply to
    That worked for me too! LOL
  • Thu, Aug 4 2022 6:05 AM In reply to
    • CBMEDIA
    • Joined on Wed, Feb 16 2022
    • Posts 8
    • Points 40
    Thank you! This worked for me in 2022 - great they keep all these active!!!
