Latest post Fri, Jan 28 2011 9:49 PM by gabocaba. 7 replies.
  • Sun, Apr 4 2010 6:10 AM
    • Posts 11,589
    • Points 256,000
    Tutorial: Colouring the Timeline - Revisited
    It is one of those very simple things that are not always obvious to newcomers.
    Also, from version 4 of MC, the way of choosing individual clip colours has a new dialogue box.
    So let's revisit some of the ways of adding colour to your timeline.
    Regards,
    Douglas
    This tutorial can be viewed at "Full-screen" by clicking on the icon on the toolbar
  • Wed, Sep 15 2010 6:48 AM In reply to
    Re: Tutorial: Colouring the Timeline - Revisited
    Hello,
    I cant seem to get to get the tutorial you posted about coloring the timeline to play. Is there another way to watch it?
    best regards
    Per
    ________________________________
    Per Sandholt - Editor
    www.persandholt.dk
    +45   20 82 49 48
  • Wed, Sep 15 2010 7:00 AM In reply to
    • Posts 11,589
    • Points 256,000
    Per Sandholt:
    Hello,I cant seem to get to get the tutorial you posted about coloring the timeline to play. Is there another way to watch it?
    best regards
    Per
    Hello Per,
    This is a problem between some of the MAC browsers and the way the Avid site plays back the FLV files.
    If you try and use Firefox you should get it to playback without problems.
    Regards,
    Douglas
  • Fri, Jan 28 2011 7:59 PM In reply to
    • gabocaba
    • Joined on Thu, Oct 15 2009
    • Buenos Aires, Argentina
    • Posts 41
    • Points 590
    Hi, I'm not sure If I'm supposed to reply here. I have a problem with local color. Once I applied a local color to a clip, how can I remove it?
    Right now I have applied a local color to a clip, but I don't want it to have any local color, and I want it to have the same color as all of the clips on the track, which I can change with the "track color" option.
    In the tutorial I see that you have inside the Edit/Set local clip color the option of "None", but I only got a set of colors to pick (not the names, nor the "none" options, just colors).
    I'm on MC5.03 Any thoughts?
    i7 930 - windows 7 ultimate 64 - quadro fx1800 - 6gb ram [view my complete system specs]
  • Fri, Jan 28 2011 8:00 PM In reply to
    gabocaba:
    Edit > Set Clip Color > None
    ciao,
    Carl
    Media Composer 2022.10 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Fri, Jan 28 2011 9:15 PM In reply to
    • gabocaba
    • Posts 41
    • Points 590
    Hi, yes, the thing is that I don't seem to have that option. Under Edit I only have "Set Clip colour to default" and "Set local clip color" which opens a tab with a palette of colors, but not options as "none". The display I get is different from the one in the tutorial.
    And I'm on Avid 5.0, not 5.3, my mistake.
  • Fri, Jan 28 2011 9:25 PM In reply to
    • Posts 11,589
    • Points 256,000
    gabocaba:
    Hello Gabocaba,
    You are correct the Tutorial was done with MC 4.0.5
    In MC 5, a lot of the controls that could be used with colouring tracks and clips were either modified or removed!
    Regards,
    Douglas
  • Fri, Jan 28 2011 9:49 PM In reply to
    • gabocaba
    • Posts 41
    • Points 590
    That's what I was afraid of. That means there's no way to remove a local color from a clip in MC5? That's crazy.
    To further the problem, the colors in the local clip color are saturated, and the ones in the tracks are pastel.
    I know thanks to you (again) in this thread that you can select any kind of color for the tracks. So If I want to remove a local color, the only way I see to do this is using saturated colors, so I can "disguise" the local colors by putting saturated colors on the tracks and using those as default.
    The shame is I don't like saturated that much, and I couldn't find a way to put pastel colors to the local color clips.
