I need help please!
So i'm batch capturing using a Z1. The last two clips are giving me this message [attached]. I already tried remounting the tape, relaunching MC, rebooting, cutom preroll...
The project is a normal 1080i HDV project. I am actually batch recapturing them as full res. I started with an offline resolution (15:1s).
Ervz Tia | Video ProductionsWM Communications, Asia-Pacific | Philippines
Just an idea,
I had this message once and I found out that the tape was write protected.
Good luck
Thanks.
Well I think I got it. I uncheked "extend handles.." and it worked. Not sure how.
"Extend Handles" tells the capture process to start/end outside the Master Clip boundries. If this TC doesn't actually exist, then you may receive the error you experienced.
"There are few technological barriers. You can fix almost anything if you throw enough money at it."*******************************Randall L. Rike, ACI, ACSR Mac*Win*Unity*ISIS*DSSystems Engineer @ BET Networks [a Viacom company](wwld)
