Hiya, Im trying to import a video off a Sony HDV FX1, and the first time it imported a clip for three minutes before a message appears saying " Capture aborted due to lack of progress the media captured to this point may be unusable and/or incomplete" i tried again with a few methods, and now it will only capture abou 20 seconds before the mesage appears. I've tried all sorts of different variations but same message appears.
plase help!
regards
Ali
I have seen this message hundred of times with Z1 and HV30.
There is no cure.
Just retry, go back the tape and retry.
Desktop
Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Asus 3060 12GB|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
Laptop
MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)|W11 Pro
NLE
DR Studio 18.1.2|MC 2022.12
3 Heads Digital Films
Try capturing to a different drive or partition.
patersonap: Hiya, Im trying to import a video off a Sony HDV FX1, and the first time it imported a clip for three minutes before a message appears saying " Capture aborted due to lack of progress the media captured to this point may be unusable and/or incomplete"
hardware questions = system specs , system specs and system specs
Tomas
Turn off the timecode track when you capture. SHOULD fix the capture.
You can add the TC back after capture with the Modify command (and a little mental math )
It doesn't. It's the small timecode breaks that MC doesn't like.
It does here, unless someone has recorded using the fast start option.
There is also a console command to increase the TC break tolerance though I have had little success with that.
Set tolerance of timecode break detection during capture across timecode breaksSYNTAX tcbreaktolerance 4NOTES The digitize window/capture window must be open while entering the consolecommand.This command sets the interval after which the system will check for a TC break. Thedefault is to check the timecode every 6 frames during capture. Shortening the intervalwill catch the breaks earlier. It may also avoid a Timecode ‘slip’ which happensoccasionally where the timecode on part of a clip can be off by several frames due tothe (rather lengthy) timecode check interval.CAUTION A setting below 3 is impractical – it will generate too many error messages when thereare not any. The minimum practical setting seems to be 3.As stated above, type this change into the console with the Capture window active forit to work.
I heard about this thanks Andrew.
I didn't know that the capture window must remain open.
This is the only thing I haven't tried yet.
The only thing dissapoints me in MC is the capture and HDV.
But I manage to capture what I want but sometimes with many retries.
Even the captures from HDV Split generates errors when imported to MC and I have to cut out some frames.
This indicates that there are errors in the tapes. However it is strange to me as I have never had problems capturing in Liquid HDV with EZ Capture tool.
sverkalo:However it is strange to me as I have never had problems capturing in Liquid HDV with EZ Capture tool.
As you can see from "This command sets the interval after which the system will check for a TC break. Thedefault is to check the timecode every 6 frames during capture." in my last post Avid regularly checks the deck.
FWIW Many of my HDV capture problems when using FW reduced significantly when I set the decks menu to HDV INPUT and HDV output.
