Latest post Sun, May 4 2014 12:17 AM by jwrl. 11 replies.
Page 1 of 1 (12 items)
  • Sun, Apr 19 2009 7:31 PM
    • btwien
    • Joined on Thu, Jan 15 2009
    • Mali, West-Afrika
    • Posts 169
    • Points 2,615
    Time line / bigger size V & A tracks?
    Hello all,
    This is prob. a simple question, but I pose the question any how. I looked in the 100 something tutorials and was hoping to find my answer in :
    Clips on Timeline - Information Customisation
    but didn't ....
    I would like to have a BIGGER size V & A tracks  - meaning the height - in my time line. How do I customize this?
    Thanks for your help!
    MC 5.5.3 Academic Version QT 7.7 Working with: PC, Windows 7, SP 1 Intel(R) Core(TM)i7 CPU 950 @3.07GHz 3.06 GHz NVIDIA Quadro 2000 [view my complete system specs]
  • Sun, Apr 19 2009 7:43 PM In reply to
    Re: Time line / bigger size V & A tracks?
    With the track indicators on (purple) press CTRL+L to make the tracks bigger, and CTRL+K to make them smaller.  You can also make tracks larger and smaller by clicking and dragging in between the track indicators themselves.
    good luck,
    Carl
    Media Composer 2022.12.2 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Sun, Apr 19 2009 8:27 PM In reply to
    And don't forget saving customized timeline views, espcially when working with fully vertically expanded audio tracks.
  • Sun, Apr 19 2009 10:41 PM In reply to
    • Posts 11,593
    • Points 256,090
    Hello Btwein,
    I see Larry already answered your question.
    I am sorry you could not find your answer in my 109 Tutorials........ I hid it under the title of "Link 39  Resizing Timeline Tracks"
    It looks like this:
    There are a couple of follow ups
    Link104  Track Height - all the same size   and
    Link108  Track Height - all the same size - REVISITED
    Maybe you can pick up a little more info from those too.
    Good Luck,
    Douglas
  • Mon, Apr 20 2009 11:41 AM In reply to
    • btwien
    • Mali, West-Afrika
    • Posts 169
    • Points 2,615
    Hey Larry,
    Thanks for the tip. It might be obvious to you, but HOW do I save the customized timeline views?
  • Mon, Apr 20 2009 12:02 PM In reply to
    btwien:
    At the bottom of the timeline, to the right of the segment editing arrows, is a box.  Click on it and select Save As and then you can save the current timeline view.
    An advanced move is to link that timeline view to a workspace of the same name, then assign the workspace to a key. Take a look at this post for an example of what I'm talking about.
    good luck,
    Carl
  • Mon, Apr 20 2009 12:47 PM In reply to
    • btwien
    • Mali, West-Afrika
    • Posts 169
    • Points 2,615
    Hey Carl,
    I found it, did not know you meant the "Unlisted" box...thanks ;)
    I will wait with the advanced move until I know my way around more in Avid, thanks any how!
  • Mon, Apr 20 2009 12:56 PM In reply to
    Here is a tutorial on toolsets and workspaces.
  • Mon, Apr 20 2009 3:48 PM In reply to
    All of this info is in the Manual!
    Customizing Timeline Views
    • Manipulate the height of tracks or move tracks as part of a view
      For more information, see “Enlarging and Reducing Timeline Tracks” on page 286 and “Moving Timeline Tracks” on page 286.
    • Save different custom views that you can call up instantly in various circumstances
      For more information, see “Managing Customized Timeline Views” on page 287.
    Then,
    You can enlarge or reduce the height of one or more tracks to improve visibility and display more information within the tracks. For example, you can use this feature to:
    •Reduce and view all the tracks in a multilayer sequence, and enlarge them when finished.
    •Enlarge all tracks to view waveform plots or other displays in multiple tracks.
    You can save these changes with a Timeline view.
    To enlarge or reduce the height of tracks:
    1.Select the tracks in the Timeline that you want to resize.
    For more information, see “Selecting Tracks” on page 305.
    2.Do one of the following:
    t Select Edit > Enlarge Track or Edit > Reduce Track.
    t Press Ctrl+L (Windows) or Command+L (Macintosh) to enlarge the track, or
    Ctrl+K (Windows) or Command+K (Macintosh) to reduce the track, which changes
    the height of all highlighted tracks in the Timeline.
    You can save a customized Timeline view. Timeline views appear in the Settings list in the Project window. You can save, rename, and copy multiple views.
    Your Avid editing application saves the Timeline information from the Timeline Fast menu with each view.
    11 Using the Timeline
    288
    You can select alternate views from the View menu located in the Timeline bottom toolbar. The Timeline view is labeled Untitled until you name and save a customized Timeline view.
    You can replace a Timeline view with a different view, while keeping the same name. You can also restore the default Timeline setup at any time.
    nYou can also change the name of a Timeline view or delete a view from the Settings list in the Project window. For more information, see “Naming Settings” and “Deleting Settings” in the Help.
    To name a Timeline view or to change a view’s name:
    1.Click the View Menu button, and select Save As.
    The View Name dialog box opens.
    To replace a Timeline view:
    1.Type a name for the view, and click OK.
    2.Press and hold the Alt key (Windows) or Option key (Macintosh) while you click the View Menu button to display the list of saved view names, each appended with the Replace command.
    3.From the list, select a view name that you want to replace.
    The current Timeline view is applied to the selected name, and that name is displayed in the Settings list in the Project window.
    To restore the default view in the Timeline:
    t Click the Timeline Fast Menu button, and select Default Setup.
  • Sat, May 3 2014 1:08 AM In reply to
    I need help finding out how to make my effect icons smaller in my timeline. I am not sure what i did but for some reason in my video tracks 1-2 any effect icon that I drop are larger then on my other video tracks.
    All my video tracks are the same sized it's just the icons that are larger and need them to get smaller.
    Thank you, for any help.
    Avid Media Composer 8.3 W/Nitris DX, HP Workstation z820, Windows 7 64bit, 16gb Ram, Intel(R) Xeon(R) CPU E5-2640 0 @ 2.50GHz 2.50GHz (2 processors) [view my complete system specs]
  • Sat, May 3 2014 5:59 AM In reply to
    I don't know of a setting to change effect icon size.  I think the way it works is based on track size, and that at a certain point the icon size automatically gets bigger or smaller as you make the tracks bigger or smaller.
    GalvanAle:
    I'd guess tracks V1 and V2 are ever so slightly larger than your other tracks - not enough to notice when you're looking at them, but enough to trigger the larger effect icons.  Try making V1 and V2 slightly smaller and see if that helps.
  • Sun, May 4 2014 12:17 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,453
    • Points 98,470
    camoscato:
    That is what happens, and it has been the way that Avid functions as long as I can remember.  But also clip length in the timeline can affect the effect icon size.
