Latest post Tue, Jan 27 2009 7:56 AM by Marianna. 2 replies.
  • Mon, Jan 26 2009 6:38 AM
    • Posts 11,589
    • Points 256,040
    The Replace Edit Button
    It's not in your default layout.
    If you've never heard of it you probably will never look for it, let alone find it.
    So here it is.........
    Regards
    Douglas
    PS. This tutorial has been updated after Siencs kindly pointed out an important point I had missed in the original Tutorial. Thank you Siencs. Smile
    The playback screen can be maximised by using the "Full-screen" button on the control bar.
  • Tue, Jan 27 2009 12:24 AM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Aberystwyth, Wales
    • Posts 441
    • Points 5,210
      Avid Certified User
    Re: The Replace Edit Button
    Hey Douglas,
    Just wanted to point out that the replace edit command is a playhead to playhead replacement. The frame that you park the playhead on in the source monitor will be inserted at the point that the playhead is in the timeline. So if you want the frame in the source monitor to be the inpoint you need to position the timeline playhead at the first frame of the clip to be replaced.
    MC Symphony 8.8.5 on MacPro 3GHz 8-Core Xeon 12GB RAM, OS 10.12.6, Blackmagic Ultrastudio 4K MC Symphony 8.8.1 on iMac [view my complete system specs]
  • Tue, Jan 27 2009 7:56 AM In reply to
    • Posts 11,589
    • Points 256,040
    Thanks Siencs,
    A very important point.
    One that I missed completely.
    I will redo the Tutorial and make the necessary adjustments.
    It may take a day or so before I get round to it.
    Douglas
