Latest post Wed, Jul 2 2008 1:56 PM by ED-it. 10 replies.
Page 1 of 1 (11 items)
  • Wed, May 28 2008 6:17 PM
    • jtr
    • Joined on Wed, May 28 2008
    • Posts 3
    • Points 45
    Marquee - title and shapes not saving/rendering correctly
    I need some help with Marquee. Every once in a while when I am working with titles, I type the words (or create the shapes) and place and move them around on the screen. Everything looks fine. But when I exit and save the title to the Bin the saved file is distorted....some of the words are various levels of opacity, some are fine. If I re-load it and make any sort of saveable changes (for example moving the text or adding spaces) the problem areas change but are still there.
    I'm really stumped. It seems like a bug, anyone have any ideas of a fix?
  • Wed, May 28 2008 11:50 PM In reply to
    Re: Marquee - title and shapes not saving/rendering correctly
    When you export it within a video file does it seems distorted?
    Otherwise might be the VGA as well.
    Desktop
    Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Quadro P2000|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
    Laptop
    MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)
    NLE
    DR Studio 18.1|MC 2022.10
    3 Heads Digital Films
  • Thu, May 29 2008 1:42 PM In reply to
    • jtr
    • Posts 3
    • Points 45
     Not sure what you mean "export it within a video file".
    When I am creating the title in Marquee it looks 100% perfect, but once I play the file back in the timeline or from the bin portions of it are distorted.
    It only happens occasionally and it seems the more separate objects I have on the screen (separate text boxes) the more prone it is to happening.
    Does that help?
  • Thu, May 29 2008 5:24 PM In reply to
    When you export as QT file for example the titles are distorted or only at screen???
    Desktop
    Laptop
    NLE
  • Thu, May 29 2008 5:38 PM In reply to
    jtr:
    Corrupt user settings can cause weird stuff like that.  Try creating a new user and see if the problem is still there.
    Good luck,
    Carl
    Media Composer 2022.10 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Fri, May 30 2008 2:51 AM In reply to
    • Chad
    • Joined on Fri, Oct 14 2005
    • Sydney, Australia
    • Posts 101
    • Points 1,190
    In Marquee, have you set the bit depth in Render > Options from 8 to 16?
    I've had similar issues in the past - and this fixed it.
    Avid MCA 3.0 on WinXP SP2 3Gb RAM [view my complete system specs]
    Filed under: , , ,
  • Fri, May 30 2008 12:04 PM In reply to
     I'm experiencing exactly the same issue. I tried setting the render options from 8 to 16, and there was no change in my case.  What I have noticed is that this happens at random - every time you resave the title, something else's opacity changes
    Avid Media Composer 2021.6 HP ZBook 17 Gen3, i7-6700HQ CPU @ 2.60Ghz Win 10, 64GB RAM [view my complete system specs]
  • Fri, May 30 2008 1:25 PM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 511
    • Points 6,225
    I've had this too.  I find it only happens with 2D titles within a 3D layer.
    Try moving the title a little bit forward ie: change it's Z position to 0.1.
    Or else extruding the text a little can help - thus giving it a little weight.
    Media Composer 2021.2.0 Dell Precision 5820, 64GB, i9-9920x, Quadro P2000, W10 2004 [view my complete system specs]
    @jaketheeditor
  • Fri, May 30 2008 1:44 PM In reply to
    • jtr
    • Posts 3
    • Points 45
     Thanks everyone for your help.
    I changed it from 8 to 16 Bit and that fixed it and seems to be working fine.
    Thanks again!
  • Fri, May 30 2008 1:46 PM In reply to
     Thanks for this.  Just tried it and it does seem to improve a little.  In my case I'm probably better off just doing a new title altogether, I've noticed that the quality of the adjusted title does seem to deteriorate in that it starts to look jagged around the edges.
  • Wed, Jul 2 2008 1:56 PM In reply to
    • ED-it
    • Joined on Tue, Jun 17 2008
    • Posts 1
    • Points 5
     Hey, thanks for the bit depth tip. I was ready to burn my Marquee until I read your solution… and I mean with a match and not to disc.
    I’m a new user on the whole Avid scene, so this helps out loads.
