DQS
www.mpenyc.com
daktulus:(HDCAM is only 3:1:1 and not accepted by some tv-stations because of that, at least in Europe)
P2 is great is for short form since the media management is relatively simple. Shoot, transfer media in to NLE, edit and output. This is great. However, once you involve long form projects, especially multi episodic shows P2 is a complete mess. Reality shows, documentaries, new magazines, etc is far from the ideal shows for P2. 1. P2 media - time consuming conversion to other codecs for offline editing. 2. P2 metadata - not bulletproof to make sure metadata info is preserved when moving the media around. If the directory structure of the P2 folders are not maintained throughout, you can lose meta and sometimes even connection to the raw media stream (like multi file clips being disconnected) 3. Archiving - in order to shoot you need a laptop on the field with multiple FW drives. You shoot, transfer to FW drives, make a backup of FW drives while you ship first drive to post facility, wait for OK to delete backup, while you keep shooting, rinse and repeat. Kind of cumbersome and adds more work not meant for your DP (of course you can always add the extra cost to the assistant DP or PA). 4. Arching Part II - since you will convert the media to offline res, you will need to backup your large full res DVC Pro HD and DVC Pro50 files. Cheapest is firewire drives. So on top of your network or local storage you will need to budget several drives. Ideally you don't want super large drives because if one fails you can end up losing dozens and dozens of hours of footage - FOREVER. 5. Onlining - You can't just import the media needed (aka Consolidated portion). You need to bring in the entire clip. Now multiply these 12 times for a typical one season. A typical doc or reality have at least 100 hours of footage per episode (200+ is not uncommon). That is at least 1 TB of long term archiving, 80GB x 2 for short term archiving/transfer (shoot and transfer), time to convert files to offline res, etc. etc. Now you get the idea. I have not even delved in to the problem of say converting P2 media. Have you tried converting P2 720/24p to something else you can offline with while preserving meta (hint: near impossible)? How about standard-def dub with TC burn in from P2 HD footage? There are no decks. Workaround is use NLE workstation time. That is least efficient way of using thousands of dollars of equipment.
But when you compare the format, it will come, because it is superior (better quality, cheaper)
As a footnote UK channels BBC, ITV & C4 have adopted it as a prefered delivery format.
http://www.digitalproductionpartnership.co.uk/technical-standards/
It's a fast changing landscape. HDCAM as 3:1:1 was great compared to SD material but very poor compared to true HD footage.
DVCPro HD is (was) a great codec for the computer of the day and the subsampled picture looked ok on moderate sized screens.
But that's all changing.
The UK broadcasters have agreed to a minimum acquisition datarate of 50Mbps moving to 100Mbps in the future (that future being a year or 2 away, or maybe less)
So a whole raft of cameras will no longer be suitable for HD broadcast work (they barely were anyway!)
And of course P2 can produce proxy files which can be AMA kinked and used with ease. So longform can and does work.
Media management of just about any format is only a mess if you manage it that way.
Yes we see shooting ratios of 100's to one but that can all be made to work seamlessly if the post house knows their stuff.
I'll be really glad when HDCAM as a format dies. It's so cruel to nice footage!
And here in the UK we will see AVC-Intra as the delivery spec for broadcasters. Coupled with the Avid Nitris DX boxes having the ability to have AVC-Intra cards installed and suddenly it's no workload on the CPU at all.
And far from P2 being a mess Panasonic have managed to handle a format in a really robust way.
Unlike Sony and their XDCAM and the various derivatives of it. How many media formats do you need!
BUt we do have AVC-Intra support. You can ingest it. Consolidate it and do SAS exports of it.
Thanks for the replies Pat. I'm going to use Adobe Media Encoder until Avid has a solution.
Cheers,
Daniel
