Take a look at the Digital Cut tool in your manual or online help for all the options available. It is explained there in much greater detail than I could explain it here.
good luck,Carl
A little Google search for you !
http://www.avid.com/dnxhd/index.asp
http://en.wikipedia.org/wiki/DNxHD_codec
http://www.studiodaily.com/main/technique/casestudies/8063.html
http://biz.yahoo.com/bw/070415/20070415005065.html?.v=1
HTH
sep
Web site : www.audiacom.com
Press ctrl + i when the record monitor is highlighted and type in the new timecode for your sequence to start at. I think you could probably crash record that to tape with the tc from your sequence with your decks tc set to ext.
I tend to use tapes that are striped and use record run on the deck.
Mike Kruft. Nottingham, UK
Thanx for the shortcut mate. ctrl + i and set the deck relative 20seconds before to the timecode, record 15sec of blsck and bob's your uncle!
http://invesure.co.nz/style/images/InvesureLogo.png
Thanks also for the ctrl + i shortcut.
John
