Latest post Mon, Nov 14 2005 3:06 PM by janacolleen. 10 replies.
Page 1 of 1 (11 items)
  • Sun, Nov 13 2005 9:40 PM
    Exporting as Quick Time Movie: Error: File exceeds limit of 2GB, change export settings???
    I am trying to export a quicktime movie (not reference), about half way through I get an error that the file limit size for exporting is 2gb, recommended to export a shorter duration or change my export settings?
    There are no export settings to change the file size limit, i know you can change the file size limit for capturing, but has anybody heard of this?  I am using quicktime 6 because 7 does not work with my 4.6avid.
    Jana
  • Sun, Nov 13 2005 10:19 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,944
    • Points 82,920
    Re: Exporting as Quick Time Movie: Error: File exceeds limit of 2GB, change export settings???
    Can you elaborate on export settings ? It's very unusual to stall on 2 Gb for Quicktime...
    Menno
    35+ MC's - 224TB Isis - 2.2 PB Spectra T950 - Interplay - 2 Media Central's - 3 TM's - 2 STP's - 500 TB Isilon - 2 Vantage - MOG SPeedrail... [view my complete system specs]
    Twitter Account
    "If you do what you did you will get what you got!"
    My Keys
  • Sun, Nov 13 2005 10:23 PM In reply to
    the error just said, to make the file a shorter duration or change export settings?  meanwhile export settings done allow you to change how big of a file to export.
  • Sun, Nov 13 2005 11:07 PM In reply to
    • Baklap
    • Posts 6,944
    • Points 82,920
    ok but what are you using as settings? A qt movie can be a 10 minute piece compressed to 1 mb but it can also be exported uncompressed at 70 Mbps.. need some settings and codecs you are using...
    Menno
    Twitter Account
    My Keys
  • Mon, Nov 14 2005 2:54 AM In reply to
    My settings I'm using are:
    Quicktime Movie
    checked off use enabled tracks
    same as source
    use dv codec
    video and audio
    4:3 square pixel
    using Xpress pro 4.6, quicktime 6.0, I have never seen this error before and I have been able to export as quicktime movie at this length of video.
  • Mon, Nov 14 2005 4:03 AM In reply to
    • video652
    • Cincinnati, OH
    • Posts 525
    • Points 6,230
    Have you tried deleting your MCState, Site Attributes and Site Settings?
    HP Zbook 17 G2. 16gigs of ram, Nvidia k4100m [view my complete system specs]
  • Mon, Nov 14 2005 5:19 AM In reply to
    • Ragu
    • India
    • Posts 13
    • Points 205
    u just try deselecting avid dv codec... and export...
    regards,
    udayath
  • Mon, Nov 14 2005 1:50 PM In reply to
    I tried deselecting avid dv codec
  • Mon, Nov 14 2005 2:13 PM In reply to
    • DonR
    • Irving, Mexas
    • Posts 225
    • Points 3,165
    I have used Quick Time Movie for the last four (4) underwater video DVD's. The QTMovie is exported so it may be MPEG-2 encoded and I have not experienced a file size problem. I'll be happy to share my detailed instruction sheet if you would like to have it.
    SuperMicro Superworkstation 7045A-T Computer Hardware: 1-Supermicro Sys-7045A-TB 4U Xeon 1333FSB FB-DIMM 6XSATA Motherboard X7DAE 2-Intel... [view my complete system specs]
  • Mon, Nov 14 2005 2:23 PM In reply to
  • Mon, Nov 14 2005 3:06 PM In reply to
    Huh? [:^)] Re: Exporting as Quick Time Movie: Error: File exceeds limit of 2GB, change export settings???
    Alright, I got it to work!! It turns out I just needed to free up extra space, even more space then what the file needed.  Thanks for all your help!!
