Dave S.
Did some OC, didn¨t happen so much, same percent in the show stoppers
Have tested both the origin catalyst driver included with the card and the newest catalyst version, makes no difference
--- General features ---Requested API: AutomaticGraphics card driver: Newer than qualified!HW TV Out: YesFree video Memory: 507MBMax Texture Size: 4096,4096PShader Version: 3.00 (Effects&ColorConversion)VShader Version: 3.00
--- Special features ---Anisotropic filtering: up to x16Seperate alpha blender: Yes in Hardware
--- Configurations ---Resolution: NTSC PAL 720p 1080i 1080pRender API used: DX9 DX9 DX9 DX9 DX93D Hardware used: Yes Yes Yes Yes YesYUY2 AUX Buffers: 30 30 30 28 28RGBA AUX Buffers: 20 20 20 18 18Recursive Buffers: 8 8 8 8 8Output Buffers: 15 15 15 13 132x RGBA streams(fps): 1264(rt) 1184(rt) 63(rt) 211(rt) ----2x YUV streams(fps): 1739(rt) 1337(rt) 370(rt) 306(rt) ----4x YUV streams(fps): 877(rt) 697(rt) 203(rt) 160(rt) ----
Moviebox Deluxe: realtime (726fps)
--- Test results ---Passed: 70ShowStoppers: 4 (14 ,30 ,64 ,78 )Warnings: 4 (16 ,33 ,34 ,63 )
__________________________________Detailed Report_________________________________________
AppVersion: Check3D - V2.1.0.4 started.System : 2 CPUs foundDate&Time : 10/06/2006 14:33
Tomas
Installation Ready, made a complete new installation, opsys and AL.
--- General features ---Requested API: AutomaticGraphics card driver: Newer than qualified!HW TV Out: YesFree video Memory: 505MBMax Texture Size: 4096,4096PShader Version: 3.00 (Effects&ColorConversion)VShader Version: 3.00
--- Configurations ---Resolution: NTSC PAL 720p 1080i 1080pRender API used: DX9 DX9 DX9 DX9 DX93D Hardware used: Yes Yes Yes Yes YesYUY2 AUX Buffers: 30 30 30 28 28RGBA AUX Buffers: 20 20 20 18 18Recursive Buffers: 8 8 8 8 8Output Buffers: 15 15 15 13 132x RGBA streams(fps): 1260(rt) 1255(rt) 63(rt) 213(rt) ----2x YUV streams(fps): 1695(rt) 1350(rt) 361(rt) 305(rt) ----4x YUV streams(fps): 872(rt) 692(rt) 200(rt) 171(rt) ----
Moviebox Deluxe: realtime (727fps)
--- Test results ---Passed: 73Warnings: 5 (16 ,33 ,34 ,64 ,78 )
AppVersion: Check3D - V2.1.0.4 started.System : 2 CPUs foundDate&Time : 10/06/2006 14:56
And now the first test, a hdv2 clip, 43 sec export to wmp hd 1080 file.
Time to make the file, 9,38 minutes, both cores running at between 95 and 100%, cpu temperature 48 C.
My other machine makes that file in 32 minutes...
Desktop PC
Corsair RM750X|Asus Ζ690 TUF Gaming WiFi D4|i5 12600K@4.9|Corsair 128G DDR4 3200|PNY Quadro P2000(511.79)|Samsung 980 MVME 500GB (OS)|2X1TB Samsung 980 NVME RAID 0|2x1TB Crucial MX500 Backups|LG BH16NS40|W11 Pro 64bit|Media Composer Software 2021.12 with Symphony Option on Dongle|Samsung 4K 32'' Monitor|M-Audio AV30 Speakers
3 Heads Digital Films
Tomas,
How long is the clip in realtime play?
sverkalo:It seems that we are not ready for HD.But are we ready for HDV?Because your test isn't for HDV but for HD.While it's quite an improvement over the P4 it doesn't seem attractive.We'd need almost 15 hours for an Hour of WMP HD file.
Hi George
Yes, it do still take a lot of time but I think it is better now, if I organize my working routines in a good way.
I do some dvd-disks with bonus folders, putting a wmf hdformat file into that folder. With my old machine, a 17 minutes clip took 20 hours, that is really terrible.
With the new machine, I will be able to make that file in maybe 5 hours and a 30 minutes project in maybe 8 hours, that is one night.
Working routine as follow:
1. Make a iso file or ts folder of the project, watch it to see if it is good.
2. Backing up the project.
3. When evening comes or I am leaving my computer for a couple of hours, (many hours...) make a wmf for hd.
4. Coming back to the computer, watch the wmf file, burn the dvd-disk with ts folders and bonus folder.
moodman: Tomas, How long is the clip in realtime play?
43 sec as I wrote or do you mean something else?
mjolnarn:I do some dvd-disks with bonus folders, putting a wmf hdformat file into that folder. With my old machine, a 17 minutes clip took 20 hours, that is really terrible. With the new machine, I will be able to make that file in maybe 5 hours and a 30 minutes project in maybe 8 hours, that is one night.
Hey folks,For some reason, my second monitor won't go full screen anymore. It's a bit intermittent i.e.. shutting down sometimes helps. But most of the time it just won't work.Is this a video card thing?*** Also, here is a possible clue. Under the VIDEO PLAYBACK window it says "(Missing) Digital Cinema - Desktop Preview -Full Screen" is greyed out or in other words missing.Any insight would be appreciated.Thanks!here are my specs:Processor 2 x 2.26 GHz Quad-Core Intel XeonMemory 6 GB 1066 MHz DDR3 ECCGraphics NVIDIA GeForce GT 120 512 MBSoftware OS X 10.9.5 (13F1096)MC 7.0.4.3
Trevor Ambrose editor Schitt's Creek
https://www.imdb.com/name/nm0024430/videoplayer/vi3076373529?ref_=nm_ov_vi
