Latest post Wed, Nov 16 2022 3:31 PM by ck123. 2 replies.
  • Fri, Nov 11 2022 4:44 PM
    • ck123
    • Joined on Wed, Jul 17 2013
    • PA
    • Posts 231
    • Points 2,925
    EDL CUEDOS Line Limit?
    Does anyone know if there is a 999 line limit for CUEDOS formatted EDLs? Trying to export an EDL cue sheet from a sequence in Media Composer 2022.7 but it will only output up to line 999. Then it gives an error stating the number of lines that couldn't be exported. Using a different output format it will export 1152 lines without error. Unfortunately, delivable requirement is in CUEDOS format.
    HP zBook 17 G3, G4, G5, G6; HP z220, HP z240, HP z420, HP z440, HP z840, HP Z4 G4, HP Z2 mini G4, Z2 mini G5, Dell Precision 3420 & 3430, Dell Precision... [view my complete system specs]
  • Sat, Nov 12 2022 5:11 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,892
    • Points 31,995
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: EDL CUEDOS Line Limit?
    Hi ck123,
      I'm sending this to the support team.
    RalphC
    MacBook Pro 15 2018 Intel Core i7 2.6GHz Mac 10.15.7 Intel UHD 630. [view my complete system specs]
  • Wed, Nov 16 2022 3:31 PM In reply to
    • ck123
    • PA
    • Posts 231
    • Points 2,925
    Following up in case anyone else has this question. Support responded that it's a built-in limit. Exporting tracks individually or splitting a sequence into blocks is required to work around.
