I've been using 2022.10 for a few days now and crashing (frozen beach ball) quite a lot. Tasks like overwrite, insert, lift, quit, etc. have all caused a freeze up crash. Force Quit is the only way out. Today I moved all my projects from the Documents/Projects folder to the Shared/Projects folder. 0 crashes in the last 4 hours. Food for thought if you're experiencing multiple crashes like I was.
Conformity is the jailer of freedom and the enemy of growth. Motion Inc
Hi Todd,
I hope you’re doing well! I've started a case for this crashing issue. Support team will reach out to assist you.
RalphC
Hey Todd. Did you ever get this sorted. I have a very similar set-up and had NO luck since I added the DNXID. Constant spinning ball doing the simplest of editing. Can you cut with the DNX ID?
Cheers
