Latest post Sun, Nov 6 2022 8:44 AM by luca.mg. 5 replies.
Page 1 of 1 (6 items)
  • Sun, Oct 23 2022 3:25 PM
    • MattB
    • Joined on Tue, May 9 2006
    • Shepperton, UK
    • Posts 485
    • Points 6,630
    Problems with linking to footage with alpha channel from After Effects
    I have been doing some work in After effects (simple lower thirds templates supplied by client).
    I usually output DNxHD files with alpha channel from AE and link to MC. This is so thsat I can amend the AE file (if necessary) and re-output to same file name and it will automatically update in MC.
    For soe reason this seems to have stopped working. MC seems to have a problem with the alpha channel and produces exception errors. I made sure I had the correct Nvidia drivers installed and upgraded to 2022.10 but it hasne resolved the issue.
    If I do the export from AE as Prores 4444 with alpha it all works, but the Avid DNxHD (or DNxHR) cause MC to freeze.
    I wondered if anyone else has encountered the issue and if so worked out what the cause is.  Meanwhile the workaround appear to be work in ProRes4444.
    Regards
    MattB
    Edit 1:- Intel Core i9 7900X msi x299-SLI-plus mobo 64GB DDR4 3000Mhx memory NVIDIA Quadro P4000 (Nvidia driver 441.12) Samsung 860PRO SSD 512GB system... [view my complete system specs]
    Matt B
  • Mon, Oct 24 2022 7:49 PM In reply to
    Re: Problems with linking to footage with alpha channel from After Effects
    Does this happen on one project or multiple projects?
    which version of MC were you using prior to 2022.10?
    Editing Movie Magic.
    My Equipment & System Specs
    Media Composer Ultimate 2022.7 | Pro Tools Studio 2022.7 | Avid Play | Sibelius Artist 2022.7
  • Tue, Oct 25 2022 3:49 PM In reply to
    • scocklin
    • Maryland
    • Posts 686
    • Points 8,315
    You might have better luck and better quality if you output a PNG sequence, rgb + alpha file from After Effects.
    HP-Z6-G4 Workstation, 1-Xeon 4216 16 core processor, 64GB 2933MHz DDR4 ECC Memory, P4000 GPU, 512GB NVMe 1TB NVMe, Thunderbolt 3 controller, 1 Blackmagic... [view my complete system specs]
  • Mon, Oct 31 2022 6:19 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 485
    • Points 6,630
    Hi Phillip - This happens on multiple projects. I was running version 2022.7 prior to the upgrade however linking to output from After Effects has been unreliable for some time, it seems since the implementation of UME instead of Quicktime it seems.
    I'm thinking I should do a clean install on MC instead of the 'in-place' upgrade. As soon as I get a moment ...
    Matt B
  • Mon, Oct 31 2022 6:21 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 485
    • Points 6,630
    Thanks for the suggestion. Bizarely, using a ProRes output from AE works better than a DNxHD one.
    Matt B
  • Sun, Nov 6 2022 8:44 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,950
    • Points 70,365
    Is AfterEffects running off a recent Mac? If yes I'm not surprised, Apple only want You to use ProRes, they're killing support for other file formats.
    Symphony 21.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
