Latest post Wed, Sep 21 2022 4:33 PM by vaster. 2 replies.
  • Mon, Sep 19 2022 11:00 AM
    • vaster
    • Posts 2
    • Points 20
    ERROR : Assertion failed: IsValidPosixPath(tmp.getTerminatedBuffer())
    Hello Helpful Avid Community Folks!
    I'm running Avid Media Composer Ultimate 2022.7.0 on a MacBook Pro (15-inch, 2016) : 2.6 GHz Quad-Core Intel Core i7 /Memory 16 GB 2133 MHz LPDDR3 // macOS Monterey Version 12.2.1
    I keep getting an error message that says:
    FILE:/Users/username/Builds/workspace/MC/Release_Installer_Git/Mac_Build/coresw/core/src/filesys/AMacFileSystemObject.c, Line: 579
    An option to click "Debugger / Continue / Exit Application / Create Report" is below the message.  I'm able to get by for a bit with Continue... but the system eventually crashes. I tried trashing the msmFMID.pmr and msmMMOB.mdb on the main drive. I've noticed there is a __bg.1 bin in the MXF folder. I am not doing any background transcoding... maybe I can delete that folder?
    Any thoughts/insights/ideas?
    Thanks -
    brandon
    ________ PClass Registry _______________________________________________
    Table size:             72 bytes
    Registered classes:     288
    Unknowns encountered:   0
          Class-Name       PCID  Version Version-Read  Minor-version-extensions &
                                 Written   Min   Max   Attributes supported
                  omf2TIFD tifd     0       0     0    NO_EXTENSIONS
      WorkspaceLinkageSetting WLst     1       1     1    NO_EXTENSIONS
                   A23Node A23n     1       1     1    NO_EXTENSIONS
            WAVEDescriptor WAVE     1       1     1    NO_EXTENSIONS
        TabDecorationState Tabs     1       1     1    NO_EXTENSIONS
                   A23Tree A23t     1       1     1    NO_EXTENSIONS
          ATrimModeSetting TMst     5       1     5    NO_EXTENSIONS
                 ATimeWarp WARP     2       1     2    NO_EXTENSIONS
           AGeneralSetting GENS    10       1    10    NO_EXTENSIONS
                  omf2JPED jped     0       0     0    NO_EXTENSIONS
                  omf2MSLT mslt     0       0     0    NO_EXTENSIONS
       MPEGAudioDescriptor MPGA     1       1     1    PCLASS_EXTENSIONS2( PCLASS_EXT(SubframeAlignment, 1), PCLASS_EXT(Origin, 2))
  • Tue, Sep 20 2022 3:53 PM In reply to
    • Posts 11,592
    • Points 256,065
    Re: ERROR : Assertion failed: IsValidPosixPath(tmp.getTerminatedBuffer())
    Hi Brandon...
    ere is a good thread where Randy Rike a long time MC user and former Avi employee explains....
    How many GB can be in one avid media files mxf folder?
    Good read and also good practices outlined in the thread.  Ping me directly if this doesnt help you.
  • Wed, Sep 21 2022 4:33 PM In reply to
    • vaster
    • Posts 2
    • Points 20
    THANK YOU! Is this the thread you are speaking of...
    https://community.avid.com/forums/p/74573/417186.aspx
    Do you think having too many mxf files in one folder is part of the problem?
    AND/OR... is the fact that I have Avid MediaFiles on two different hard drives?
    The main folder on the main drive has (251.51 GB on disk) for 504 items... but there is another drive with 9 folders from older projects.
