Latest post Tue, Jan 31 2023 10:44 AM by Kevs999. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Aug 31 2022 3:57 AM
    • Spectro
    • Joined on Wed, Sep 24 2008
    • Posts 178
    • Points 2,515
    Go into Effect Mode --> Effect Editor Not Showing Up
    Hello,
    This little thing has driven me bonkers for a while.
    Example: I have an effect on the timeline that I want to adjust the parameters for. So, I click over into Effect Mode using the tab on the right side of the screen. Now, even though I have taken the time to carefully lay out all of my tabs to be the "perfect" Effect Mode configuration... it all goes out the window. Whenever I click on the Effect Mode button, the Effect Editor window does NOT appear. This is despite the fact that I specifically configured it to appear within the Effect Mode layout.
    So, EVERY single time I go to edit the parameters of a clip effect, I have to go up to the Tools menu, and then select Effect Editor.
    It drives me crazy.
    I've tried new user settings, reset Effect Mode to default. reset to default then change again... nothing works.
    Any ideas?
  • Thu, Sep 1 2022 1:50 PM In reply to
    Re: Go into Effect Mode --> Effect Editor Not Showing Up
    Is it that it's not there at all or it's not populated with the effect parameters? And don't forget that clicking the TC track will make it vanish. Don't do that unless you plan to play more of the sequence in the monitor than just the effect clip.
    iMac i5 27", 40GB RAM, OS 11.6.4 with MC 2022.7 with Symphony option, BlackMagic 4K. 2020 MacBook Air with MC 2022.7 ... and NewsCutter 7.x on Dell... [view my complete system specs]
    ACI, Dorset, UK. www.avid-companion.co.uk
  • Thu, Sep 1 2022 2:52 PM In reply to
    Spectro:
    Just to make sure, did you save the Effect Mode workspace after setting it up how you want it? If not, that might be why it's reverting to a different configuration the next time you click on the workspace button.
    Media Composer 2022.12.2 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Thu, Sep 1 2022 5:30 PM In reply to
    • Spectro
    • Posts 178
    • Points 2,515
    To answer the above notes... the Effect Editor is just not there at all. I have to go up to the top menu to manually re-activate it.  I tried to attach a screen shot, but it doesn't seem to work.
    I have re-saved the configuration many times. But every time I go from Edit to Effect mode, the Effect Editor is a blank panel that says "Effect Editor" on the left vertical area, but has no parameters or controls.
  • Thu, Sep 1 2022 6:05 PM In reply to
    Parameters will only show up if any effect is present on the clip you're parked on, on the selected V-track.
  • Thu, Sep 1 2022 7:01 PM In reply to
    • Spectro
    • Posts 178
    • Points 2,515
    Yes, I am aware of that. I have used Media Composer for about 20 years, so the fact that it's not working as expected is very confounding.
  • Thu, Sep 1 2022 8:07 PM In reply to
    • mcdannyj
    • Joined on Sun, Oct 9 2011
    • Posts 94
    • Points 1,310
    Spectro!
    Totally agree!
    I made the same complaint as you in another thread a few days ago:
    https://community.avid.com/forums/t/207427.aspx
    Something is definitely broken with the Effects Editor when you always have to manually activate it.
    2019 Macbook Pro 2.4 GHz Intel 8 Core i9 ● 64 GB RAM ● 32" Asus Proart PA329C Display ● Media Composer 22.7.0 (on Mac OS X 12.4) [view my complete system specs]
  • Thu, Sep 1 2022 8:23 PM In reply to
    • Spectro
    • Posts 178
    • Points 2,515
    I'm not glad you're having the same problem, but glad it's not just me!
    I have tried as many ways as I can think of to figure out how to "unbreak" it. I have made the effect to be edited the only active video track before going into Effect mode. I have selected the clip within the timeline before going into Effect Mode. I have created new user settings. I have set the Effect Mode settings to factory default.
    Nothing works.
  • Thu, Sep 1 2022 9:14 PM In reply to
    • mcdannyj
    • Posts 94
    • Points 1,310
    I've tried all the same thing you've tried. Hate to be negative but I don't think there's anything we can do. I think Avid needs to note this as a bug (or we have to get it officially reported as such) and get their coders to find an under-the-hood fix.
  • Tue, Jan 31 2023 10:44 AM In reply to
    • Kevs999
    • Joined on Mon, Jul 18 2016
    • Posts 56
    • Points 780
    Hi
    Having recently installed 2021.12 I have also noticed this issue. Previous versions I was using it was fine but now I have to manually restart effect editor which really slow the workflow.
    I guess this may have been addressed in a later version.
    Playing around I have just found that if i click in to the effect editor panel when it is open and showing effect editor (i manually re loaded it) then save the workspace, it now does appear when i call up effects workspace in the sidebar.
    Whether this stays I will see.
    i7-5930K Windows 10 Professional 64 bit 32GB RAM GTX 970 AJA Kona LHE Plus I/O Internal 7TB Raid [view my complete system specs]
