Hi there community. Assistant Editor on scripted features here. I'm curious if anyone knows of (keyboard) shortcuts or speedy workarounds for some of these bin tasks I encounter a LOT.
Mac OS Mojave 10.14.6MacBook Pro (13-inch, 2019, 2.4 GHz Intel Core i5, 8 GB 2133 MHz LPDDR3)
Avid Media Composer Ultimate 2020.12.1
I don't think you can edit values AND load into source montior.
You can edit values much like Excel or Google Sheets. Once you click on a field and are in edit mode return and tab, shift-return and shift-tab, will allow you to move around and change values. But, I don't know anyway to enter this mode with the keyboard.
When you're not in edit mode, the return/enter key will load into the source monitor. You can then use "find in bin" to go back to the bin and use up/down arrows to move to other items.
To remove suffixes and more, you can run "find and replace" on the contents of a bin. It's in both the Edit menu and the Bin menu, "Find and Replace". Why this isn't in "bulk edit" I don't know.
Thank you! These were some helpful time-savers. Especially once I mapped 'Find Bin' to the keyboard.
For anyone following, the 'find and replace' command is availalbe in v.2020.X onwards.
