Latest post Tue, Aug 9 2022 11:38 PM by Chris Bové. 11 replies.
Page 1 of 1 (12 items)
  • Wed, Aug 3 2022 2:49 PM
    • marluc
    • New York State
    • Posts 514
    • Points 6,505
    Desperate for help with interlaced project
    Is it possible for me to create and export from Media Composer 2022 on Mac OS Catalina as the following:
    ProRes 422HQ
    D1/DV NTSC (0.9091)
    interlaced
    lower field first
    non-square pixels
    Please help.  I am going nuts trying to get this old project to export correctly to view on CRT monitors!
    Many thanks,marluc
    DESKTOP: 27" iMac/3.5GHz Quad Core i7/ 32 GB 1600 MHz DDR3, 8GB/1TBFlash Storage/NVIDIA GTX 780M 4GB, running OS X 10.15.6 and MC Ultimate version... [view my complete system specs]
  • Thu, Aug 4 2022 1:42 PM In reply to
    Re: Desperate for help with interlaced project
    Hi, this might help: https://community.avid.com/forums/p/160685/810764.aspx
    So far i've never actually had to work in interlaced so I don't know how to setup interlaced avid projects...
    Editing Movie Magic.
    My Equipment & System Specs
    Media Composer Ultimate 2022.7 | Pro Tools Studio 2022.6 | Sibelius Artist 22022.5
  • Thu, Aug 4 2022 3:15 PM In reply to
    • marluc
    • New York State
    • Posts 514
    • Points 6,505
    Yes, Philip, it seems that Avid has dropped certqain legacy capabilities and everyone I have spoken with thinks it can't be done with the current MC version.  I never should have upgraded my OS or my Avid app, but at the time I didn't realize what the consequences would be.  Those of us who are old enough to have worked in these early formats need access to older versions of everything and should NEVER upgrade on at leaste one computer saved for that purpose. What I need is Avid MC 2018+ and whatever Mac OS supported that. What do I do?  Wipe out one computer and go bacwards?  Oh my!
    marluc
  • Thu, Aug 4 2022 3:58 PM In reply to
    • dlogneb
    • Joined on Wed, Aug 27 2014
    • Posts 186
    • Points 2,050
    A Windows PC might be your answer.
    Avid MC 2022.7 Mac Os Monterey (12.3.1) MacStudio Apple M1 Ultra 128GB [view my complete system specs]
  • Thu, Aug 4 2022 6:42 PM In reply to
    marluc:
    I don't get that. If you are in an SD project, set to interlaced in the Format settings (PAL or NTSC), you should simply choose File, Export to File, click Options, choose MOV from the dropdown menu, and choose
    - Source Raster: Project Raster
    - Image Preset: NTSC (image size will show 720x486), choose Aspect Ratio 4:3 (pixel aspect ratio will flip to 0.9:1)
    - Frame Rate: choose 59.94i for NTSC
    - Color Space: Keep As Legal Range
    - Compression: Apple Pro Res, ProRes 422 HQ
    - Audio: PCM, stereo
    Are you saying none of this works for you?
    I mean, following your requirements here:
    ProRes 422HQ - That's available in MOV exports
    D1/DV NTSC (0.9091) - D1 NTSC would be 720x486, standard
    interlaced - this option is available under frame rate
    lower field first - I think this is a given for NTSC, but I'm not entirely sure about this one
    non-square pixels - that's implicit in the 720x486 D1 NTSC 0.9091 spec
  • Thu, Aug 4 2022 6:52 PM In reply to
    OK, darn, I just noticed there is no 59.94i frame rate available in the MOV exporter.
    Can you try to export MXF Op1A instead, then use Shutter Encoder to re-wrap from MXF to MOV?
  • Thu, Aug 4 2022 8:07 PM In reply to
    • marluc
    • New York State
    • Posts 514
    • Points 6,505
    Unfortunately, it always comes out Progressive. All contemporary versions are geared towards progressive.  Interlaced is a thing of the past, and there is no solution escept NEVER TO UPGRADE!
    marluc
  • Fri, Aug 5 2022 2:55 PM In reply to
    Does the legacy quicktime engine not have this format? It should be under QuickTime movie in the export settings?
  • Fri, Aug 5 2022 3:53 PM In reply to
    Philip Kapadia:
    marluc is running a post-Mojave Mac system, so no access to 32-bit apps, meaning no access to Quicktime.
    Media Composer 2022.7 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Fri, Aug 5 2022 4:54 PM In reply to
    marluc:
    ProRes 422HQ
    D1/DV NTSC (0.9091)
    interlaced
    lower field first
    non-square pixels
    Hello,
    MOV exporting in modern versions of Media Composer utilizes the UME exporting rather than Quicktime. So yes, the dialogue window you see is different. However changes were made to accommodate this. It is now dynamically detecting the resolutions and the project frame rate, and then presenting options for exportig based on that.
    For example, I am currently running MC 2022.7 and am in a 1080i5994 project, dealing with DNxHD HQ clips that are interlaced. I can hit export, and I can see MOV as the export platform, and then inside of that window, I can indeed see 59.94i as a format.
    However in the US, interlaced exports for broadcast are all upper-field first. I see on your specs you are showing lower-field first. I haven't tested this myself, but it might be a reason why the detection is not happening. Are you able to load an upper-field first clip into the Source Window and test its export list?
    Quite often when working with other editors in the past, I remember them using lower-field first as a method of exporting clips that are interlaced in order to get them to "look good" in progressive projects. Could it be possible that you need to go back to the original interlaced video fotage and commission them to be re-exported?
    2014 MacPro 6;1 "trashcan" on Monterey with MC 2022.7. 2019 MBP (Intel) with BigSur running MC 2021.12.2 2014 MBP (Intel) with Mojave running... [view my complete system specs]
    Email me to create a support case: chris.bove@avid.com
    Chris Bové
    Avid Online Community Manager
  • Tue, Aug 9 2022 11:14 PM In reply to
    • Editmvp
    • Joined on Wed, Sep 3 2008
    • Billings, Montana
    • Posts 168
    • Points 1,955
    Hi Chris, I've been testing the new export capabilities with 22.7 and have found that even with a NTSC 30i project created, a 720x486 30i with lower field first will only export as progressive or upper field first.  The NTSC 720x486 preset only allows the 16x9 option at 59.94i.  When changed to 4x3 aspect ratio, the 59.94i option is not available.  AFAIK, NTSC 30i has always been lower field first and was the broadcast standard for decades prior to HDTV.  The only way to correct it is to give the operator the option to choose the correct field order for the project.  Otherwise, the only current work around I can find is to use an older version of MC.
    Primary System: Media Composer Ultimate 2021.12.x | Avid Artist DNxIO | iMac 2020 i9 10-Core 3.6/128GB/2TB-SSD/Radeon Pro 16GB / OS 10.14.6 | Artist Color... [view my complete system specs]
  • Tue, Aug 9 2022 11:38 PM In reply to
    There may be a discrepancy in the way different broadcasters ask for deliverables.
    I've spent my years delivering to PBS, which demands upper field first. You can refer to this guide on page 5, addendum 3.6.2 on "Field Dominance": http://bento.cdn.pbs.org/hostedbento-prod/filer_public/PBS_About/Producing/Red%20Book/TOS%20Pt%201%20Submission%202016.pdf
    In times when I was contracted as an archivist for museums, all of our exports in 720x486 at 30i were upper field first. When colleagues of mine did the work in lower-field first, and it was played back on older DVD players, that's when jittering was seen and I was brought in to fix their work... which of course meant redoing it, since field dominance conversions really didn't exist in any sort of a good way back then.
    Is there any way to obtain the original media you gained access to and have it digitized brand new, thus existing in a fully upper-field-first flow?
    Chris Bové
