Latest post Thu, Aug 4 2022 2:15 PM by Rasego68. 7 replies.
  • Tue, Jul 26 2022 5:04 PM
    • Rasego68
    • Joined on Sun, Nov 1 2020
    • Posts 24
    • Points 280
    Media Composer with Fast Track noisey
    Have a Media Composer V 8.5.3 with Fast Track Audio V 6.1.11, after using Media Comnposer for a while the Audio on the headphones start to have a lot of noise, had to restart the application (MC) to fix the noise.
    HP Z420 Interl(R) Xeon(R) CPU E5-1650 0 @ 3.20GHz, 16 GB RAM
    Any ideas will be greatly appreciated
    Ramon Servin
  • Thu, Jul 28 2022 8:38 PM In reply to
    • Rasego68
    • Posts 24
    • Points 280
    Re: Media Composer with Fast Track noisey
    Has anyone seen this on their systems?
  • Fri, Jul 29 2022 4:42 PM In reply to
    Hi there,
    Were you always getting lots of noise when using this plugin, or has this suddently started happening?
    Can you tell me if you are seeing this issue with all your Avid projects? or just one project in particular?
    How do you have your audio routed? where are your headphones plugged into?
    Editing Movie Magic.
    My Equipment & System Specs
    Media Composer Ultimate 2022.7 | Pro Tools Studio 2022.7 | Avid Play | Sibelius Artist 2022.7
  • Fri, Jul 29 2022 9:32 PM In reply to
    • Rasego68
    • Posts 24
    • Points 280
    Hi thanks for replying.
    - It just started a few weeks ago
    - It happens with any Avid Project
    - The Audio is comming from the ISIS Storage and we have a Fast Track Audio device where the headphones are plugged in.
    Appreciate any input.
    Ramon
  • Sat, Jul 30 2022 9:10 PM In reply to
    Okay, and where are the headphones plugged in? Through the computers motherboards soundcard, OR do you have an I/O breakout box with an SDI demuxer?
  • Wed, Aug 3 2022 5:49 PM In reply to
    • Rasego68
    • Posts 24
    • Points 280
    The headphones are connected to an M-Audio Fast-track device, which is connected via USB to the PC.
    What I have seen is that I need to restart the Media Composer app, to fix the issue, it happens randomnly meaning it could happen the same day or it could take a few days to have the Audio with noise.
    Regards
  • Thu, Aug 4 2022 1:35 PM In reply to
    Does this happen with any other program or just with Media Composer?
    I'm trying to figure out if this is an issue with your system, configuration, or media composer..
  • Thu, Aug 4 2022 2:15 PM In reply to
    • Rasego68
    • Posts 24
    • Points 280
    This PC only has Media Composer
    Regards
