Latest post Fri, Apr 22 2022 2:08 PM by Vadym. 2 replies.
  • Mon, Feb 21 2022 4:20 PM
    Production Management CTMS not returning MOB Complete attribute
    When using CTMS to retrieve the attributes of a master clip the com.avid.workgroup.Property.System._OMM_MOB_COMPLETE attribute is not returned. This means that it is not possible to determine whether a master clip is complete or not when using CTMS. If someone has inadvertantly (or perhaps foolishly) created a USER version of _OMM_MOB_COMPLETE then that value is returned.
    This is unlike Interplay Web Services where adding com.avid.workgroup.Property.System._OMM_MOB_COMPLETE to a list of requested attributes does indeed retrieve the value.
  • Mon, Apr 4 2022 2:08 PM In reply to
    • Vadym
    • Joined on Thu, Apr 17 2014
    • Posts 262
    • Points 3,110
    • Avid Developer Moderator
      Avid Employee
    Re: Production Management CTMS not returning MOB Complete attribute
    Hi Mike,
    You'll have to use IPWS to retrieve this specific attribute for now. In the mean time we have submitted a feature request to make this available in CTMS
  • Fri, Apr 22 2022 2:08 PM In reply to
    • Vadym
    • Posts 262
    • Points 3,110
      Avid Employee
    Hi Mike,
    Glad to inform you that this attribute can be obtained through CTMS with some extra configuration.
    Using Admin app you need to enable "Record Complete" property availability by default, then OMM_MOB_COMPLETE will be present in the attributes list response.
