Hello,
I am currently working on a project that is meant to be shown in 2.35 aspect ratio. So far, I have been working with a filler that creates letterbox to 2.35. However, the main editor would like to have the monitor set to 2.35 instead of working with a filler in the timeline as it can be annoying to work with. I was wondering how I would go about modifying the monitor to permanently be viewed witht the letterbox or if there is a frameflex option?
Thank you
Open your project format settings, set Mask Margins to 2.39:1 (or 2.35:1 if they insist, but the real world aspect ratio in Digital Cinema is 2.39:). Then in Video Output Settings, choose Black Mask. You can right-click in the Source and Record monitors and set the same mask there. Or you can set transparent masks.
Thank you so much ! Works great:-)
Note that you can also select these mask margins to be applied when exporting to MOV/MXF/MP4 etc.
