Latest post Thu, Sep 16 2021 1:56 AM by dmfreeman. 4 replies.
  • Wed, Sep 8 2021 12:10 AM
    • 220070
    • Joined on Wed, Sep 8 2021
    • Posts 10
    • Points 160
    Can't see Avid Export option anywhere
    Hello I am not able to see my avid export option annywhere. I have check:
    1-Right clicking the program monitor
    2-right click the sequence
    3-going to file and Output option is missing.
    Please help me. Thanks folks!
  • Wed, Sep 8 2021 9:48 AM In reply to
    Re: Can't see Avid Export option anywhere
    220070:
    Hello, Are you on MC first? I seem to remember that in MC first the export option is called "publish" or something like that.
    If you are on the full MC or MC | ultimate, what version are you on?
    Editing Movie Magic.
    My Equipment & System Specs
    Media Composer Ultimate 2022.7 | Pro Tools Studio 2022.7 | Avid Play | Sibelius Artist 2022.7
  • Thu, Sep 9 2021 12:50 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,865
    • Points 24,715
    If I understand you correctly, you will have to mark an in and an out around the sequence or frame that you want to export on your timeline (usually) then go to File>Export and follow the prompts there.
    Hope this helps,
    Denny
    Media Composer 2019.6, BCC Continuum 12.5, , Boris Red 5.6., Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows 10 Pro 1803... [view my complete system specs]
  • Thu, Sep 9 2021 4:50 AM In reply to
    Hi Denny,
    Depending on the version of MC or MC First being used, there may not be an 'Export' option under the File menu. On 2020.6, for example, the user would need to select File > Output > Export to File.
    Media Composer 2022.10 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Thu, Sep 16 2021 1:56 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,865
    • Points 24,715
    Hi Carl,
    I stand corrected.  I was not in front of my computer when I wrote that post, it was from memory.  The correct path is File>Output>Export to file.
    Please accept my apologies if I misled anyone.
    Denny
