Latest post Fri, Sep 24 2021 5:37 AM by Norbert Kottmann. 19 replies.
Page 1 of 2 (20 items) 1 2 Next >
  • Tue, May 25 2021 8:48 PM
    MC refuses to play, but everything else is fine
    Everything in Avid functions normally, can open and save bins, media operations etc - essentially, 100% a working MC.  But it suddenly decides it simply will not play.   The play button turns green, but no sequence will play.   Restarting Avid sometomes fixes it, sometomes a full system restart is required.   I hope the answer isn't "Create a new user", because I've had to do that so many times now and it's a massive pain recreateing everything.   But that's usually the answer, right?
    MBP 2020, 2.5Ghz 8 Core, 64GB RAM, 8GB VRAM [view my complete system specs]
  • Tue, May 25 2021 8:52 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,739
    • Points 227,800
      Moderator: MCA Mac
    Re: MC refuses to play, but everything else is fine
    What version of Composer? I am seeting the same thing on the same MBP using 2021.3. My use is not heavy, or crucial, so I have not really pursued it. Going to try to create a new user though because I did not do that when upgrading from 2020.12
  • Tue, May 25 2021 8:55 PM In reply to
    MC 2021.3
  • Tue, May 25 2021 9:00 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,739
    • Points 227,800
      Moderator: MCA Mac
    Thanks. I'll let you know what happens after I create a new User
  • Tue, May 25 2021 9:01 PM In reply to
    After you've done that, I'm assuming you're building a tool to allow us to create a new user and import our old settings.   Right?
  • Tue, May 25 2021 9:04 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,739
    • Points 227,800
      Moderator: MCA Mac
    You don't need a tool. Just open your old settings file and drag the setting you want into the setting window in Composer.
  • Tue, May 25 2021 9:07 PM In reply to
    Try trashing MC State (in the Settings folder).
  • Tue, May 25 2021 9:38 PM In reply to
    BLKDOG:
    That is something I would really like to be able to do, but I'm not clear on the process.   Can you explain with a little more detail?
    Trashed MCState, made no difference.
  • Tue, May 25 2021 10:26 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,739
    • Points 227,800
      Moderator: MCA Mac
    So far, the new user seems to have fixed it. Will need to take it through a whole session to be sure
  • Tue, May 25 2021 10:39 PM In reply to
    Now I'm confident I don't even need to restart Avid, or change anything.   I just keep letting it time out trying to play, or leave it alone for a bit, and eventually it will play.
  • Tue, May 25 2021 10:57 PM In reply to
    I created a new user, still having the problem.   It's really frustrating, I'm grinding to a halt today because of it.
  • Wed, May 26 2021 12:28 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,739
    • Points 227,800
      Moderator: MCA Mac
    Phillip, Are you also running OS 11.3 on that Mac?
  • Wed, May 26 2021 12:50 PM In reply to
    Hi.
    Is this happening in every project you have?
    Where is your media storaded?
    When you play a sequence. Does it happen the same or it is something that happens playing a specific sequence?
    If so. Are linking media or regular.imported media?
    cj
    AVID MEDIA COMPOSER 5.5.3. PC. WINDOWS 7, SP1. 64BIT OPERATING SYSTEM. QUICK TIME VERSION 7.6.9. [view my complete system specs]
    Christian Jhonson
    Avid Ambassador
    christianjhonsoon@hotmail.com
  • Thu, May 27 2021 12:50 AM In reply to
    Yes, this seems to happen on any project.
    Media is stored on external Thunderbolt RAID, direct connected.
    This can happen when playing any sequence.
    I have no linked media, it's all imported as MXF.
    I updated to 2021.5 last night, but have seen the same problem today.   As another user pointed out, it does seem to have something to do with application switching.   If I switch to Safari or Mail and then back, it seems more likely to happen - but definitely not every time.  It has also happened right after starting up MC.
    I have seen it all afternoon with any sequence in my project, or with source clips, both AV and audio only.   Mostly, I just keep hittting play/stop until it eventually will play.  I've decided restarting Avid isn't much help.
    Finally, I was seeing this happen frequently under Catalina until last week's update to 11.x, so I don't see the update to 11.3 or .4 as being the issue?
