Latest post Wed, Nov 10 2021 1:18 AM by Zach Fine. 62 replies.
Page 4 of 5 (63 items) < Previous 1 2 3 4 5 Next >
  • Mon, Aug 2 2021 12:02 PM In reply to
    • PieterS
    • Joined on Tue, Mar 26 2013
    • Posts 26
    • Points 370
    Re: Sequence crashes every time it opens
    Yes, I also use iZotope plugins.
  • Mon, Aug 2 2021 1:26 PM In reply to
    • JPBU
    • Joined on Sat, Jan 11 2014
    • Canada
    • Posts 178
    • Points 2,475
    Yes, I did have some sort of iZotope plugins too. But they we're not in use in my sequences if I recall.
    Media Composer 2020.8 | iMac Pro (2017) 3.2 GHz Intel Xeon W | 64 GB 2666 MHz DDR4 | Radeon Pro Vega 56 8176 MB | G-Raid 16TB Thunderbolt 3 | macOS... [view my complete system specs]
  • Mon, Aug 2 2021 2:20 PM In reply to
    • Greg Cohan
    • Joined on Thu, Apr 9 2015
    • Hollywood
    • Posts 95
    • Points 1,090
    No izotop for us but we do have
    BCC
    ssphiire
    and
    mocha
    60 Systems all running MC 2021.6 0n Catalina [view my complete system specs]
  • Mon, Aug 2 2021 4:16 PM In reply to
    • Greg Cohan
    • Hollywood
    • Posts 95
    • Points 1,090
    This just happened again.  None of the tricks worked.. Had to throw the work away and start from scratch.
    It's like working with a ticking time bomb.
  • Mon, Aug 2 2021 4:31 PM In reply to
    • Greg Cohan
    • Hollywood
    • Posts 95
    • Points 1,090
    saw another fix to try
    console
    RepairSequence.
    and they *** thing opened.  at least this time.
  • Mon, Aug 2 2021 4:38 PM In reply to
    Holy cow, this worked for me!
    I'll report back if it ends up not working in the future, but it just saved my morning! Thank you!
  • Sun, Aug 15 2021 9:20 PM In reply to
    • tudora
    • Joined on Sun, Feb 19 2012
    • Posts 24
    • Points 290
    Didn't work for me. I have the same setup and same issue
  • Thu, Sep 16 2021 11:06 PM In reply to
    • Greg Cohan
    • Hollywood
    • Posts 95
    • Points 1,090
    Repair Sequence just stopped woking for us however...
    If your seqeunce contains subcaps...
    Find another system if available and open your bin. Duplicated the sequence. Open the duplicate. Deleted the "Subcaps in the duplicated sequence and save it. Go back to the bay that crashed and opened the bin. Open the dupicate.  If it does not crash your orginal sequence should open fine now....
    makes no sense to me but working multiple times.
    To be fair we also did the Hokey Pkey and turned ourselves around ;-).
    Good luck.
  • Mon, Sep 20 2021 5:09 PM In reply to
    • dmabry
    • Joined on Thu, Dec 4 2014
    • Posts 7
    • Points 85
    This happened to us for larger feature-length sequence from older version of Avid being opened into Avid 2021. Sequence has subcaps, LUT. Could be any number of things. Crashes Avid 2021 every time, until we drag sequence to Source Monitor, create a new sequence and Insert or Overwrite all contents of problematic sequence into new sequence. Avid 2021 then plays the contents without a problem.
  • Mon, Sep 20 2021 5:15 PM In reply to
    Is it possible to get a copy of a sequence that reliably crashes when opened on a new Avid? It would be good to pass to Avid to investigate.
  • Mon, Sep 20 2021 5:19 PM In reply to
    • Greg Cohan
    • Hollywood
    • Posts 95
    • Points 1,090
    Not sure about original poster but avid has copies from me under Case 04180488.
    I also encounter 10 to 20 minutes start up time making trouble shoot a process that crashes your systme 9 times out of 10 and very frustration process....
  • Tue, Sep 21 2021 9:36 AM In reply to
    • Pol
    • Belgium
    • Posts 255
    • Points 3,315
    Same problem.
    Fix is to 'remove color adapters' under the refresh sequence command.
    But then again, this morning it didn't work.
    MC2021.6, Catalina, BM Decklink card
  • Fri, Oct 8 2021 9:37 AM In reply to
    • richiebh
    • Joined on Mon, Jun 6 2011
    • Posts 8
    • Points 100
    Is ayone at Avid actually doing something about this? There doesn't seem to be much of a response and it's clearly a fundamental issue since the new avid interface has been implemented. I'm working on a large show with 6-8 editors and every person on the new interface versions will have this problem 3-4 times a week. I literally can't load a sequence with any effects on it unless I load, say a rushes sequence (something without any effects) in to the source + record monitors several times. It then seems to kick start Avid into thinking it can actually work somehow. This isn't a plausible way of working though!
  • Fri, Oct 8 2021 11:55 AM In reply to
    • Greg Cohan
    • Hollywood
    • Posts 95
    • Points 1,090
    .This bug is suppose to be fix in 2021.9.
    I have about 15 of my systems testing it at this point and it feels like this and many other bugs are corrected.
  • Fri, Oct 8 2021 12:06 PM In reply to
    • richiebh
    • Posts 8
    • Points 100
    I'm going to upgrade now.. Finger crossed.
