Latest post Fri, Jul 23 2021 10:12 PM by Philip Kapadia. 60 replies.
Page 1 of 5 (61 items) 1 2 3 4 5 Next >
  • Thu, Mar 18 2021 9:10 PM
    Avid background services do not work...
    Hi all,
    Is anyone successfully using avid background services for transcoding/rendering timeline? I've never ever ever been able to get it to work on any of my systems, or at my colleges' qualified systems.
    Background services in the tray show two red arrows, Avid background service status in MC shows a red dot, and the background queue is stuck on processing.
    Any ideas?
    Thanks in advance.
    Editing Movie Magic.
    My Equipment & System Specs
    Media Composer Ultimate 2022.7 | Pro Tools Studio 2022.7 | Avid Play | Sibelius Artist 2022.7
  • Fri, Mar 19 2021 7:59 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,950
    • Points 70,365
    Re: Avid background services do not work...
    Hi there, I have had this very same problem, the fix was to uninstall MC and all related stuff except for AMA and third party effects, and manually delete whatever was left over by the uninstallers. I did not delete the license information, if unsure deactivate MC and trash everything, You Will be able to reactivate later on. Make sure You enable "show hidden/system files" in Windows Explorer, as there is stuff You otherwise won't spot. No need to delete projects and user settings! Carefully run a registry cleaner, I went with CCleaner, reboot and reinstall. Don't know if this will work for You, but it surely worked for me. I blame this issue on several MC updates/upgrades on top of each other, did You go from MC 2019 to 2020 and to 2021 without uninstalling the older release first?
    Symphony 21.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Fri, Mar 19 2021 8:21 AM In reply to
    • ZFigas
    • Joined on Tue, Jan 31 2006
    • Poland
    • Posts 186
    • Points 2,420
    I agree with luca.mg. With each update, I am concerned that Avid Background will stop working. Reinstalling the entire system helped me. Currently I have adopted a Restore policy from a working Backup. Zb.
    HP Z8 G4, 2xXeon-6246R, 128 GB RAM, Win 11 Enterprise, MC 2021.12, Nvidia Quadro RTX 4000, Boris Red 5.6, BCC 14.03, Saphire 2021.02, Adobe CC, TMPGenc [view my complete system specs]
  • Fri, Mar 19 2021 10:49 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,950
    • Points 70,365
    I forgot to mention: always right click the MC installer and select "Run as Administrator".
    peace luca
  • Fri, Mar 19 2021 2:49 PM In reply to
    luca.mg:
    Oof, thats annoying. I don't have time to troubleshoot this atm - and not in the middle of a project!
    I always uninstall before installing a new MC version. It seems to me that this feature isn't fit for purpose...
  • Fri, Mar 19 2021 9:48 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,950
    • Points 70,365
    Philip Kapadia:
    Background transcode works pretty well, I seldom use background render, since foreground renderings are quite fast and give me a welcome break, but whenever I happen to background render the feature works as advertised.
    Other than uninstalling MC before updating You should manually delete whatever is left over by the uninstaller, especially when upgrading: roughly speaking an update is a maintenance release with bug fixes, while an upgrade is a major release with new features.
    peace luca
  • Tue, Apr 27 2021 12:19 PM In reply to
    Just wondering if anyone had any additional suggestions? This is still an issue for me. I've re-installed, reset my windows computer, re-installed etc.
    Avid support won't help me very much because my system isn't on the qualified list xd.
    Thanks in advance!
  • Tue, Apr 27 2021 6:23 PM In reply to
    I've had mixed success. Most of the time it work, I use it for transcoding primarily. Sometimes it craps out. I haven't tracked to see when it works best vs. when it doesn't.
    Media Composer 2021.03 Symphony Phrase Find Script Sync Dell XPS 8940 Intel(R) Core(TM) i9-10900 CPU @ 2.80GHz 2.81 GHz 10cores 96.0 GB RAM NVIDIA... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Tue, Apr 27 2021 6:25 PM In reply to
    Scott Carnegie:
    Thanks Scott, are you on a supported system?
  • Tue, Apr 27 2021 6:31 PM In reply to
    Philip Kapadia:
    Currenlty no. I have in the past and it did seem to be more reliable then, but I have a new really fast system with lots of RAM and Processor power and I get mixed results.
  • Tue, Apr 27 2021 6:36 PM In reply to
    Scott Carnegie:
    Philip Kapadia:
    This is how support responded to me:
     This is not reproducible on any qualified system that we have available for testing.
    I'm convinced it's a bug and not my hardware.
  • Tue, Apr 27 2021 9:14 PM In reply to
    I use background services a lot and it works well for me. I'm mostly on supported systems.
  • Wed, Apr 28 2021 12:19 AM In reply to
    Pat Horridge:
    Mm interesting. I'm stumped then!
    Every other mc feature works perfectly on my system. Although my system is not supported, it runs mc perfectly well (except for this of course)
    Although it seems to be an issue with the editor transcode service, not media composer itself.
    I wish they'd support more systems...
    A few weeks ago I went over to one of the Facebook groups and made a post there similar to this one, and almost everyone commented that background transcode wouldn't work for them... Idk, maybe it'll sort itself out in a future release.
  • Wed, Apr 28 2021 8:02 AM In reply to
    I use my systems to edit and for teaching and I've been demonstrating background services since it forst came along.
    Occasionally I get issues with it not starting. But normally I can manage to uninstall and clear everything out and re-install to resolve.
    Background services does require network access you get firewall notifications you have to enable to allow it to speak to MC.
    So you may have something blocking it?
    Can you access the background Queue (either within MC or via right clicking on the two arrows in the system tray?
    Does anything show in the logs folder:
    C:\Program Files\Avid\Editor Transcode\TranscodeService\logs
  • Wed, Apr 28 2021 9:20 AM In reply to
    Pat Horridge:
    So, I can acess the background render queue through media composer, and by right clicking the two arrows in the tray as you say. The issue is that every task is stuck on pending.
    It's a bit strange, when the services start, the arrorws are green, but about 15 seconds later they turn red. I'll look into if it's something to do with firewall or windows defender.
    There seems to be nothing in the logs!
