Latest post Mon, Nov 30 2020 3:35 PM by Marianna. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Nov 17 2020 2:34 PM
    • emmanuego
    • Joined on Tue, Nov 17 2020
    • Posts 3
    • Points 45
    Time Code Burning options to display informations of the right track
    Hello everyone
    I am working on an archives documentary
    The person who is in charge of archives needs an export of the film with source time code and source clip names burned on the video
    The video archives are on tracks V1 and V2. On V2 are the B Roll, illustrations etc. On V1 are the archives with sync sound (mostly interviews, or live music).
    I know how to use TC burning plug so i have set the plug to display source time code and clip names of V1, and source time code and clip names of V2
    Everything is ok if I have a clip on V2 and a clip on V1,
    When there is a clip on V2 and nothing on V1, the plug in displays the clip informations for V2 and "N/A" for V1 timecode and "Filler" for clip name", which is not ideal but it is OK
    but if I only have a clip on V1, and nothing on V2, (which is the most frequent case) I was expected that the plug in displays clip informations for V1 and "N/A" + "Filler" for V2 , but this is not the case
    The plug in displays twice the same information (V1 and V2), because if it doesn't found something on the highest track, it displays the informations of the lowest track
    So most of the time there is too much information, which could be confusing for someone who doesn't know how all these things works...
    Is there any solutions to display only TC and Clip Name of a specific track only if there is a clip on it, and N/A and Filler if there is nothing on it ?
    Hope everything is clear, thank you for your solutions !
  • Wed, Nov 18 2020 5:09 PM In reply to
    • ericswanson
    • Texas
    • Posts 58
    • Points 780
    Re: Time Code Burning options to display informations of the right track
    I don't think the TC effect has 'if-then' logic.
    Here's something to consider as a work-around: Put your TC effect on a single track for the entire sequence. Then make the TC effect work for your first clip. Now save the effect by dragging the effect icon to a bin and label it appropriately. Then go to where the TC window does not reflect what you want and insert an edit on the TC track, splitting it in two. Now modify the TC effect settings for the split portion to show what you really want at that point, save it by dragging the icon to a bin. Continue down your timeline cutting the TC effect and then dragging from the bin the particular TC effect you want at that point. You can save as many variations of the TC effect as you want, just drag and drop on the timeline.
    Eric
    Editing on an iMac Pro [view my complete system specs]
  • Thu, Nov 26 2020 9:50 AM In reply to
    • emmanuego
    • Posts 3
    • Points 45
    Hello Eric, thank you for your answer
    I have considered this method before asking, but it is really too much work and manipulations...
    I don't think there is a good solution...
    But thank you for taking some time to answer !
  • Thu, Nov 26 2020 10:19 AM In reply to
    I've tested the issue and confirm it does behave as you describe. No easy work around I can see.
    I've posted it as a possible bug.
  • Thu, Nov 26 2020 3:36 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,091
    • Points 49,325
    Here is my sleazy idea.
    Move all V2 clips to V3 temporarily.
    Make a clip of black media. Cut into V2 at the beginning of the sequence and add an effect to make it fully transparent (Mute MIGHT work). Copy this clip with it's effect and paste for the rest of V2.
    Now go to V3, select all without gaps and move down to V2.
    This would at least always give you something other than filler on V2.
    No idea if this really would work, but hey ....
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2021 iMac w Big Sur [view my complete system specs]
    Jef Huey
  • Mon, Nov 30 2020 3:34 PM In reply to
    • Posts 11,592
    • Points 256,065
    emmanuego:
    Hello everyone
    emmanuego
    I cant create a case for you as your email is not in our system at all.  I suggest you create a case on the support portal which you can access via MyAvid master account or email me directly and include:
    The link to this thread
    Your system ID
    Your MyAvid email address
    Then I can help you.....
  • Mon, Nov 30 2020 3:35 PM In reply to
    • Posts 11,592
    • Points 256,065
    Pat Horridge:
    Hey Pat
    where did you post it - centercode?
