Latest post Tue, Oct 6 2020 4:01 PM by Movies by Matt. 1 replies.
Page 1 of 1 (2 items)
  • Mon, Oct 5 2020 10:46 PM
    Panasonic P2 Plugin Not Processed
    Hello,
    I’m editing a documentary.  The main part of the footage was shot on the P2 format. My plan is to AMA Link and transcode to DNxHD60 for an offline/online workflow.
    All the footage plays without a problem in P2Viewer Plus and FCPX.
    A large amount of footage won’t link or import into Media Composer.
    With footage from the same folder/card In the Source Browser window under Name a good clip will say the correct name “0001QV” and under Plug-in it says “Panasonic p2…” a bad clip under Name will say “Clip 2”  and under Plug-In “Not processed”
    What's strange is if I navigate directly to the VIDEO folder and Link to the MXF files it would work, though I had to link to the audio and spanned clips weren't functioning since I'm not linking to the volume
    The original card structure including the .txt file has been kept intact.
    None of my folders contain any odd characters and all are 14 characters or under.
    I believe I have compatible versions of OS/MC/P2 Plugin but I listed my specs below just in case
    Mac OS 10.11.6
    2.3GHz Intel Core i7
    8 GB 1600 MHz DDR3 Ram
    NVIDIA GeForce GT 650M 1024 MB
    MC Version 8.7.0.44700.0
    AMA Plugin Info:
     PanasonicP2 MVP_MSP Plug-In Panasonic.
    4.7.1.0
    Camera HVX200, HPX170
    Codec DVCPROHD 720/24pn (Really 23.98) and some over crank at 720/60
    I’ve read a ton on this forum and have googled my problem but nothing exactly comes up with this particular search “media composer plugin not processed”, though there seems to be plenty of people having trouble linking.  Any help would be appreciated.  Thank you, m-
    Avid Symphony 6.0.5 Mac OS 10.8.5 QT 7.6.6
  • Tue, Oct 6 2020 4:01 PM In reply to
    Re: Panasonic P2 Plugin Not Processed
    Update 1
    I installed MC 6.0.5 on OS 10.7.5 with QuickTime 7.6.6 and P2 AMA 2.6, it seems to be working smoothly so far.
    Update 2
    I Installed MC 6.0.5 on OS 10.8.5 with QuickTime 7.6.6 and P2 AMA 2.6 and it also seems to work smoothly.
