Latest post Sat, Mar 14 2020 2:45 AM by Ahmad Halimi. 2 replies.
  • Fri, Mar 13 2020 2:58 AM
    • Ahmad Halimi
    • Joined on Thu, Sep 17 2015
    • Australia
    • Posts 13
    • Points 185
    Timeline clip gain change all linked clip tracks
    I love the clip gain adjustment that you can do directly on the timeline. I think it would be more efficient if you can adjust all the tracks of a clip together. For example if a clip has 2 audio tracks, holding down Alt (Option) and adjusting the clip gain would adjust both tracks.
    Filed under: , ,
  • Sat, Mar 14 2020 2:27 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 281
    • Points 2,990
    Re: Timeline clip gain change all linked clip tracks
    To do this put in and out marks around the key frames you want to adjust, select the tracks in the track panel and adjust one key frame and the others will be adjusted also.
  • Sat, Mar 14 2020 2:45 AM In reply to
    • Ahmad Halimi
    • Australia
    • Posts 13
    • Points 185
    I'm talking about the clip gain adjustment where the fader pops up (see screenshot attached) not the volume keyframes.
    Clip gain on timeline
