Latest post Fri, Oct 25 2019 2:38 AM by ManChicken. 9 replies.
Page 1 of 1 (10 items)
  • Thu, Oct 17 2019 11:15 AM
    • spyderrp7
    • Joined on Fri, Oct 28 2011
    • Posts 84
    • Points 1,110
    How to delete a specific effect when working with multieffects
    So let's say I have 3 effects on a clip in the sequence.
    I am in the effect editor and I can see all 3 effects. How can I delete one of the 3? If I press "Remove Effect" it will delete the effect that is on top of the 3. But let's say for example I want to delete the second effect, how can I do that?
    There is a workaround with Step In and Step Out but this is too many clicks to do it.
    Isn't there a more easy way? Like for example right click on the effect editor and press delete for example?
    3950x, Ecc UDimm DDR4 64GB CL22, ASUS Pro-WS-X570-ACE, Quadro P2000, Windows 10 64bit, 2TB NVMe Seagate Firecuda 520.Blackmagic DeckLink Mini Monitor 4K... [view my complete system specs]
  • Thu, Oct 17 2019 1:07 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,488
    • Points 18,545
    Re: How to delete a specific effect when working with multieffects
    I thought you could delete stacked effects in the effects editor -- but it looks like that is not possibe.  This might be a good feature request.
    Meanwhile, mapping step in, step out and delete effect to the keyboard will make the task less onerous.
  • Thu, Oct 17 2019 1:58 PM In reply to
    While in Segment mode (red/yellow arrow), double click the clip in the timeline. It will expand with every FX on a sub-layer/track. Select the proper layer/track and press the Remove Effect.
    If the FX is not shown, it may be a sub-layer of a sub-layer. Just double click to reveal.
    MC 2022, W11, ASUS z690m, Intel 13900K, Gigabyte 3080Ti Waterforce, 128GB RAM, Samsung 980 Pro M2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2019, Big... [view my complete system specs]
  • Fri, Oct 18 2019 8:06 PM In reply to
    • spyderrp7
    • Posts 84
    • Points 1,110
    Ok so no solution to easily remove any effect without stepping in. That is so weird to me, because you can so easily do that with audio effects in the Audio Mixer Console. Really. noone asked this before?
  • Wed, Oct 23 2019 5:38 AM In reply to
    Yes...this is needed...being able to delete effects (or turn them off and on) without all these extra clicks, would be great..
    ...premiere has it...come on, avid.Yes
  • Wed, Oct 23 2019 8:53 AM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 211
    • Points 2,695
    What Dom Q. said...
    Dom Q. Silverio:
    ... can be done without closing the effect editor and without being in segment mode. You might have to activate the timeline setting "Double-Click to Show Nesting". (I don't remember if that's a default.) I know, it's not the simple right click inside the effect editor and a bypass function would be nice. But maybe quicker in some way?
  • Wed, Oct 23 2019 4:08 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    It has been asked for many times. The most effective solution is to implement what Resolve has - that is, both a toggle on/off switch for each effect and a trash can (to delete the effect). Most often I would like to disable an effect to gain some performance for trimming, etc. and then enable again (or remove). Anyway, I've never really been burdened with the way it is because I seldom remove effects once added, but when experimenting with different effect stacks, it would be rather useful.
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Wed, Oct 23 2019 8:40 PM In reply to
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Naples, FL
    • Posts 476
    • Points 6,550
    My workaround is to go into effects mode so I can see all the effects applied to the ckip and then drag each effect into a bin I call "effects" and then delete the one I don't want from the clip and then drag the 2 I want to keep back to the clip. Takes a few seconds.
    MC 2020.06 w/Symphony option. BlackMagic DeckLink 12G, HP Z840 Dual 3.2Ghz/8 Core, 1TB SSD, 1TB Cache drive, 128GB Ram, Nvidia RTX2060 Super, BCC2020,... [view my complete system specs]
  • Thu, Oct 24 2019 4:49 AM In reply to
    • spyderrp7
    • Posts 84
    • Points 1,110
    BarkinMadd:
    That would be awesome!
  • Fri, Oct 25 2019 2:38 AM In reply to
    • ManChicken
    • Joined on Mon, Feb 4 2008
    • Denver, CO
    • Posts 265
    • Points 3,455
    • Moderator: MetaFuze
    ...or they could implement a system like Avid DS had over 20 years ago where effects stack up on top of the clip, are easily disabled, deleted, re-arranged, even trimmed to only span a portion of a clip...
