Latest post Mon, Aug 1 2022 4:36 PM by DStone. 14 replies.
Page 1 of 1 (15 items)
  • Tue, Jul 2 2019 8:56 PM
    • adamsonn
    • South Africa
    • Posts 724
    • Points 10,795
    Why limited interface highlight colours in 2019?
    Hi
    I know it is not a big thing but why is 2019.6 limited to 2 highlight colours when previously there were about 7? (This is in the interface setting)
    I was partial to the default blue but am now limited to either a brightish white or a purple. Why the change in the number of colours for this setting?
    Ta
    Neil
    MC6 machine: Intel Core i7 Asus P8-H67 64 bit Motherboard 1*1Tb SATA drive - partitioned to C (OS and programs) and D (data) drive 1*1TB SATA drive... [view my complete system specs]
  • Tue, Jul 2 2019 9:36 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,856
    • Points 31,605
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Why limited interface highlight colours in 2019?
    Hi Neil,
      You are correct with the number of option, and looks like it will remain check this FAQ
    RalphC
    MacBook Pro 15 2018 Intel Core i7 2.6GHz Mac 10.15.7 Intel UHD 630. [view my complete system specs]
  • Wed, Jul 3 2019 1:04 AM In reply to
    adamsonn:
    Hi
    Ta
    Neil
    If from now on there is to be only ONE non-white highlight color, it would be very cool if the entire user base could vote on which color it will be. I dislike these two highlight choices and I can’t help wondering what others think.
    -Telegram!
  • Wed, Jul 3 2019 8:18 PM In reply to
    • bonang
    • Boston, MA
    • Posts 426
    • Points 5,330
    This is the second MAJOR dumbing down of choices/options for interface personalization. The previous "simplification" took place some six years ago with the intro of MC 7. Ostensibly the removal of many customization options was due to the overhead they required when the platform moved to full 64 bit (Avid's response when I inquired about this 6 years ago)...nonsense then and now. Overhead?
    However, I'd be happily placated (along with thousands of other users) if Avid decided to restore AT LEAST the customization available in 2018.12.x etc - though why not include what was possible prior to MC 7?!?
    Avid MC 2021.12 with Symphony option | HP zbook 17" G3 / i7 6820HQ / 32GB RAM / 512GB SSD / WIN 10 PRO 64 / nVidia m3000m w/ 461.72 driver / BMD UltraStudio... [view my complete system specs]
    Keith
  • Sun, Jul 7 2019 12:32 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,872
    • Points 49,585
      Moderator: MCA Mac
    There are a lot more settings that can be done in the ReleasedFeatures.ftf file (and since this is already posted elsewhere, let's add to the mayhem). The following setting will change the behavior of the 2019.6 skin back to the previous behavior.
    First, see this post here: http://community.avid.com/forums/p/196214/884144.aspx#884144
    The location for the Mac file is a few posts later.
    To change the UI behavior, use the follow:
      "Media Composer": {
        "ShowAllSkins": true
    Note that if you want to disable background save and change the interface, the file would look as follows:
      "Media Composer": {
        "BackgroundBinSave": false,
        "UnifiedBinSave": false,
    Just remember that unless Avid told you to do something (and I'm not Avid), altering the ReleasedFeatures.ftf files in done at your own risk.
    Dave S.
  • Sun, Jul 7 2019 1:23 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,470
    • Points 18,260
  • Mon, Jul 8 2019 11:04 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    DStone:
    ...The following setting will change the behavior of the 2019.6 skin back to the previous behavior...
      "Media Composer": {
    ...done at your own risk.
    Hi Dave - What does this do exactly? Thanks
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Jul 8 2019 11:32 AM In reply to
    • smrpix
    • Posts 1,470
    • Points 18,260
    (Not Dave here, but I'll answer.) It it seems to make the previous interface color options available.
    Only downside I can find is that it leaves the bin view option icons blank -- the buttons still work, but you can't see the icons.  (Speculation:  maybe that's why Avid didn't make it easily available with this release.)
    It's also (apparently) completely reversible, so no harm in trying.
  • Mon, Jul 8 2019 11:33 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,872
    • Points 49,585
      Moderator: MCA Mac
    This enables the interface to use the pre-2019.6 color scheme. In other words, it goes from this:
    to this:
    Dave S.
  • Mon, Jul 8 2019 12:11 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Thanks! Interesting that Avid chose to limit this...
    Steve
  • Sun, Feb 9 2020 5:47 PM In reply to
    • CinéMatica
    • Joined on Tue, Jun 24 2014
    • Belgium | Europe
    • Posts 255
    • Points 3,035
    DStone:
    to this:
    Why is it taking so long to put this normal Media Composer release? It can't be that hard to add this in a next version. Not everyone is keen on making changes themself at own risk!
    The two interface colors that are available now are completely useless.
    (Avid 1) HP Z840 | 2x 18 Core Intel Xeon E5-2699v3 / 2.3GHz 35MB | 128GB PC4-17000P 2133MHz / 8x 16GB DDR4 | NVIDIA Quadro P4000 / 8GB GDDR5 / 4x DP 5K... [view my complete system specs]
  • Sun, Feb 9 2020 6:25 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,020
    • Points 48,520
    While I might not say "completely useless" I would say "a lot less than useful".  Big Smile
    The little things like this are what are keeping me on the deadend path of 2018.12.x.  I do not think I am being an old fart on this.  I just really like a UI that has as much visual help in complicated projects as possible.  The limited palette shown above does not do that.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2021 iMac w Big Sur [view my complete system specs]
    Jef Huey
  • Tue, Jul 28 2020 5:42 PM In reply to
    • danny
    • Joined on Sun, Jan 24 2010
    • Posts 103
    • Points 1,225
    + lots
    Same with lack of several shades of dark interface - now back to boring mid grey - or light grey!
    BTW hate the fact that the subtey different grey background obliterates my mac desktop since 2018, and also makes it difficult to distinguish between various windows. I try to slide it out of the way but it never remembers its position in the workspace settings. Argggh. Apart from numerous other niggly import / link bugs (stereo tracks as default!) mp4s linking to only left channel. Oh and the titler plus(!)....... I know it's a different forum.
    MC 8.9.1 was very pretty and easy on the eyes. I still have it on the other partition. Except I admit the new version is generally faster. Maybe Avid will eventually listen and bring back some of the lost features thrown out with the bathwater that made it more pleasant to work with.
    Danny
    Mac 3Ghz 8-core cylinder Xeon E5. 32GB 1866Mhz DDR3. AMD D700 graphics x2. OS 10.12.6 with MC/Symphony 8.9.1 and 10.14.6 with MC2020 [view my complete system specs]
  • Mon, Jul 11 2022 11:17 AM In reply to
    Is the ReleasedFeatures.ftf workaround still working to get all the interface colours? I've been trying to get it working on 2021.2, but with no results.
    MC 2021.2 | MacPro6,1 | macOS 10.15.7 [view my complete system specs]
  • Mon, Aug 1 2022 4:36 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,872
    • Points 49,585
      Moderator: MCA Mac
    ReleasedFeatures.ftf is located in the C:\ProgramData\Avid\Support directory. Mine is still there, and the interface colors are still correct. Here is the text of the file:
      "Media Composer": {
    When I go into Settings->Interface, I have the light gray background with 4 not 2 colors.
    Also note that in 2021.x you can also manually change the background color of any bin to any color, but you can't change the background of the timeline or souce/record monitors. There may be settings for that somewhere, but I haven't been able to find them.
    Dave S.
