Latest post Tue, May 21 2019 11:12 AM by luca.mg. 7 replies.
  • Mon, May 6 2019 10:19 AM
    How to "consolidate" camera footage to exclude unused takes
    there's a short film edited in MC (camera footage AMA linked and transcoded to DNxHD36) which soon goes to a coloring facility. They will get an AAF and the original camera files, but is there a way to give them only the files which are involved in the final timeline?
    Thanks.
    HP Z420 MC 2018.12.3/2018.18.2/7.0.4 MINT server-client network [view my complete system specs]
  • Mon, May 6 2019 11:14 AM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,489
    • Points 18,560
    Re: How to "consolidate" camera footage to exclude unused takes
    Sure.  Relink your sequence  to your original sources,
    then check the "Copy All Media" option in the AAF export dialogue.  Copy All Media - Will copy the entire master clip, even if only a small percent is used in a seq.
    http://avid.force.com/pkb/articles/en_US/How_To/How-to-export-an-AAF
    Be aware that depending on your original sources, in many cases it may be more efficient to send them everything.
  • Mon, May 6 2019 6:42 PM In reply to
    OMG, it can't be that simple Big Smile (actually it looks like it can) I was thinking about much more complicated ways (which wouldn't work anyway) because I wanted to make the file transfer prior to the AAF export (and somehow remove the unnecessary files)
  • Mon, May 20 2019 1:15 PM In reply to
    today was the day to try this and it doesn't work Sad AMA and 'AAF Copy All' seem to be incompatible - when there is AMA in the timeline the Copy All gives an error.
  • Mon, May 20 2019 1:25 PM In reply to
    Actually I got a quite strict NO on the second attempt saying:
    "AAF export involving ProRes media using any other method than "Link To" is not allowed!"
    It was too nice to be true...
  • Mon, May 20 2019 3:08 PM In reply to
    You are on the wrong track folks.
    You don't want to include media in the AAF. All the media is proxy so no use to the grader.
    You should export out a quide video and audio movie as a reference (ask the grader what they can handle)
    For the source media you need to copy the final sequence to a fresh empty bin.
    Then in the bin fast menu select then under bin display choose show reference clips
    This will give a list of every clip usd in the final sequence.
    Now ensure the source file and source apth columns are enabled and sort by source path
    You now have a list of every source file used sorted by its location.
  • Mon, May 20 2019 4:24 PM In reply to
    Maybe the question was not clear enough (though smrpix got it). I can put anything out of MC and I can also make long lists in bins with the clips used, that's fine. But the footage is 3TB and the coloring studio asked us to select and only copy those files that are actually involved in the final cut. So I tried to get those lists out of MC to the windows file system-level... with no luck.
  • Tue, May 21 2019 11:12 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,950
    • Points 70,365
    What Pat said. Once You have the clips list exported as ALE You can write Your own batch file and copy all clips. Be aware that, depending on the camera, it might be impossible to relink to the clips in the target system if the entire file structure of the footage cards is not available.
    Symphony 21.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
