Latest post Fri, Mar 15 2019 4:55 PM by jef. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Mar 14 2019 8:52 PM
    How To ONLY Re-Wrap Upon Import Without Re-Compressing
    How do I determine which import option to use such that Avid ONLY re-wraps the CODEC to MXF without any re-compression.
    In other words, I don't want Avid to change even one single bit of data...just re-wrap to MXF so that it is a much faster import.
    The list of Import options in Media Composer 2018.12.1 doesn't provide enough information to quickly determine which option will result in the above goal.
    i9-9980xe with 18 physical cores and 36 threads (18 cores can each run at 4.4Ghz)
    128GB Corsair DRAM4 running at 3400 Mhz
    Nvidia Titan RTX Video Card
    2TB SSD Samsung
    Asus Prime X299 Deluxe II motherboard (BIOS tweaked CPU to 4.4Ghz and RAM to 3300Mhz)
    all running very cool with great temperature control
    i9-9980XE; Asus Prime x299 Deluxe II; 128GB DRAM4; Nvidia Titan RTX; SSD 2TB [view my complete system specs]
  • Thu, Mar 14 2019 10:51 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,320
    • Points 17,200
    Re: Fastest Way To Import Non-Supported CODEC
    I use EditReady for this, but I believe it's Mac only. You might be able to use Adobe Media Creator (or whatever it's called) to batch your files to ProRes or DNxHR for fast import.
    https://www.divergentmedia.com/editready
    MacPro 3.33Ghz 12 Core (Westmere, MacPro 5,1), 48Gb RAM, nVidia GeForce GTX 680, Intensity Pro (Desktop Video 10.4.3), OS X 10.13.6, MC 2018.12 [view my complete system specs]
  • Fri, Mar 15 2019 12:28 AM In reply to
    Are you AMA'ing then transcoding or are you using traditional Import command? The former is faster.
    MC 2022, W11, ASUS z690m, Intel 13900K, Gigabyte 3080Ti Waterforce, 128GB RAM, Samsung 980 Pro M2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2019, Big... [view my complete system specs]
  • Fri, Mar 15 2019 2:45 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,090
    • Points 49,320
    Re: How To ONLY Re-Wrap Upon Import Without Re-Compressing
    mrhgdomenech:
    Consolidate - don't "Import".  Yea, I know - semantics.
    A consolidate is exactly what you are looking for.  Pulls the essence from one wrapper and puts it into Avid Op-Atom mxf wrapper.
    http://resources.avid.com/SupportFiles/attach/Avid_Supported_Video_File_Formats.pdf
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2021 iMac w Big Sur [view my complete system specs]
    Jef Huey
  • Fri, Mar 15 2019 4:38 PM In reply to
    • cls105
    • los angeles
    • Posts 559
    • Points 7,240
    consolidate with the delete source option selected.
    I do this all the time with mxfs I create in ffmpeg or ame.
    w10, always the latest version of MC, diy 7940x, gtx 1080 ti. [view my complete system specs]
  • Fri, Mar 15 2019 4:55 PM In reply to
    • jef
    • Maryland
    • Posts 4,090
    • Points 49,320
    Man, I would NOT have "delete source" selected!  But that is just me.
    Jef
    Jef Huey
