Latest post Thu, Aug 11 2022 8:27 AM by Rory T. 15 replies.
  • Mon, Dec 17 2018 2:06 PM
    • mkj
    • Sweden
    • Posts 489
    • Points 6,490
    "configuring waveform cache..."
    This is so irritating, happens randomly, on random computers/projects.
    How do I disable this ***???? Big Smile
  • Mon, Dec 17 2018 10:59 PM In reply to
    Re: "configuring waveform cache..."
    Never seen this.
    Go to cahce settings and start from there.
    Have you set the cache on a separate drive?
    Desktop PC
    Corsair RM750X|Asus Ζ690 TUF Gaming WiFi D4|i5 12600K@4.9|Corsair 128G DDR4 3200|PNY Quadro P2000(511.79)|Samsung 980 MVME 500GB (OS)|2X1TB Samsung 980 NVME RAID 0|2x1TB Crucial MX500 Backups|LG BH16NS40|W11 Pro 64bit|Media Composer Software 2021.12 with Symphony Option on Dongle|Samsung 4K 32'' Monitor|M-Audio AV30 Speakers
    3 Heads Digital Films
  • Tue, Dec 18 2018 8:04 AM In reply to
    • mkj
    • Sweden
    • Posts 489
    • Points 6,490
    ok, it seems like it can take time when you open a project for the first time on a computer.
    But you can have this problem even on a computer that have open the project before. Then is one fix that you rename your computer's folder in the project, then start Avid again and a new folder will be created..
  • Tue, Dec 18 2018 5:47 PM In reply to
    As I said I never see this.
    Do not rename Avid Project's folder, if I understood what you are doing.
    Desktop PC
  • Wed, Dec 19 2018 8:53 AM In reply to
    • mkj
    • Sweden
    • Posts 489
    • Points 6,490
    no, I said that one fix for this can be renaming your computers's folder INSIDE the project folder
  • Wed, Aug 28 2019 4:11 PM In reply to
    I have been having this issue for a while now and I can't work it out. We run on an editshare shared environment. Avid will hang on 'configuring waveform cache' for around 5 minutes before Avid finally opens. This will happen on any of the 5 avid PCs we use. It seems to happen when drive letters are changed or worksapces are unmounted and remounted. It generally seems to happen in the larger projects on the system. I have tried all the suggestions above to no avail.
    Any help would be much appreciated.
  • Thu, Aug 29 2019 7:56 AM In reply to
    I guess I'm not telling you any news but make sure to mount the workspaces needed before starting Media Composer.
    MC doesn't like Workspaces (dis-)appearing while it's running.
    I'm in an Editshare environment aswell and so far don't have any startup issues while the waveform cache is configuring, even with larger projects where 4 editors are working on at the same time.
    MC 2018.12.7 @Win 7 Pro x64, HP Z440, K4200, 32GB RAM, AJA Kona LHe+ [view my complete system specs]
  • Mon, Sep 2 2019 10:52 AM In reply to
    Thanks for the reply. I always mount spaces before opening Avid. Its really strange and I don't seem to be able to workout what Avid is doing when it pops up.
  • Mon, Sep 2 2019 11:08 AM In reply to
    Does it show the same behaviour with local test projects?
    Just make a copy of a project on a local drive, disconnect from Editshare and try opening it.
    Or create a new project on a local drive, ingest some files and see what happens.
    This way you can exclude Editshare as a source of the issue.
  • Mon, Sep 2 2019 12:20 PM In reply to
    • mkj
    • Sweden
    • Posts 489
    • Points 6,490
    rename the computers folder in the project
    N:\Avid Projects\190902 PGM 216\<computername> (add an underscore or whatever you like)
    then Avid creatis a new folder and you probably dont have this problem
  • Mon, Sep 2 2019 2:19 PM In reply to
    • radrattus
    • Joined on Wed, May 9 2018
    • Posts 31
    • Points 375
    This fix has worked for me in the past, but the problem seems to eventually return.
    My Mac systems seem to be more susceptible to such slowdowns.
    Toggling wfTglPersistence in the console seemed to speed things up, but that command does not seem to be persistent.
  • Wed, Sep 25 2019 10:07 AM In reply to
    Hi all,
    I've just run a test by copying the project to the desktop and seeing if the waveform cache hang would be replicated. When opening the project from the desktop there was NO hang at all. This seems to confirm it is an Editshare issue.
    No solution as yet.
  • Wed, Oct 2 2019 7:13 AM In reply to
    Hi AmazingProd,
    I also have this issue but only on some workstations. I have a big reality project and sometimes it is configuring audio waveform cache for over a hour. It happens every time I reboot the machine that I have to wait for it. So I dont reboot that much when I need to get work done in that project.
    The thing that is different in this project is the use of scriptsync and phrasefind. Maybe it has something to do with it?
    have you tried this? http://avid.force.com/pkb/articles/en_US/Troubleshooting/MC-hangs-configuring-audiowaveform-cache?retURL=%2Fpkb%2Fapex%2FKB_Render_Download%3Fid%3DkA240000000KzTk%26lang%3Dit_1_1_2_1_1_2_1&popup=true
    Running MC 2018.12.7 on win10 on NEXIS E4 with a project worth 35TB of footage.While I have sort of learned to coop with this behaviour it is anyothing and I am not sure how to resolve it. I am also goingt to test if it is related to user settings.
    Z4 G4, Z800, Z420 MC 2018.12.7 win 10 nexis-e4 [view my complete system specs]
  • Wed, Oct 9 2019 9:59 AM In reply to
    Hi Julian,
    I have now escalated this to our supprot company who are in contact with Avid. Currently no fix.
    I have also tried that fix in the link above but it doesn't do anything.
    Hopefully I'll have a useful update soon.
  • Mon, Aug 1 2022 10:46 AM In reply to
    • Rory T
    • Joined on Wed, Mar 21 2018
    • Posts 94
    • Points 1,085
    Was there ever a fix for this?  I tried the flush cache and the rename computer folder in the project folder but still hanging.
    Normally renaming the folder works but not this morning.  I could try a re-install/mc state etc but I can open other projects on the nexis and local quickly.
    The license does have script sync and phrase find although they are not needed for this job.
    Is there a way of disabling them?
