Latest post Fri, Aug 3 2018 8:26 PM by cuervo. 2 replies.
  • Fri, Aug 3 2018 2:54 PM
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 1,174
    • Points 15,780
    1000 MB/sec on two thunderbolt external drives
    Quite by mistake, I set up a Windows RAID 0 using one SSD each on a different Thunderbolt 2 bus controller. When I ran the Blackmagic disk speed test on the RAID, it clocked write speeds around 1000MB/sec. Pretty much surprised me because the same two drives RAIDed together on the same T2 bus clocked at 650MB/sec.
    SYS1:ASUS Z97, Haswell 4.0GHz CPU, 32GB RAM, Quadro 4200 + GTX1070, Thunderbolt II -DNxIO-FSI CM171 ///SYS2:ASUS Maximus Extreme V, Sandy Bridge 3.1GHz... [view my complete system specs]
  • Fri, Aug 3 2018 4:03 PM In reply to
    Re: 1000 MB/sec on two thunderbolt external drives
     If your PC has 2 different TB2 controllers then the results are to be expected. MP 6,1s have 3 controllers and we often get these kinds of numbers.
    On the same TB2 controller reaching only 650 MB/s, this is likely caused by the SATA chipset or how it is interacting with the TB2 controller.
    MC 2022, W11, ASUS z690m, Intel 13900K, Gigabyte 3080Ti Waterforce, 128GB RAM, Samsung 980 Pro M2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2019, Big... [view my complete system specs]
  • Fri, Aug 3 2018 8:26 PM In reply to
    • cuervo
    • Santa Fe, NM
    • Posts 1,174
    • Points 15,780
    Thanx for confirming, Dom. What a pleasant surprise that this works.
