I just updated to the new 2018.2 with a clean install that support was helping me on. I created a new user profile. Everything is fine except when I go to full screen nothing plays and then it crashes. I did not have a problem before upgrade to 2018.2 with this system.
I tried admin user, reboot, color space change Ycbcr 709 and RGB 709, on settings/full screen playback I have left 0, right 1920, top 0, bottom 1080. am I missing a settings with this new install?
MC 8.4.5 Built Workstation-Windows® 7 Professional, 64bit,/ Intel® CoreTM i7-4770K processor/ NVIDIA Quadro K2000D 2GB/16GB Dual Channel DDR3 SDRAM at 1600MHz /MSI Z87-G45 Mother Board/650 Watt Power/ Super Multi Blue Writer (LG BH12LS38)/ AVID C-400 for audio interface Pro Tools MP
ask support to upgrade your computer to Win 10. Everything gets better!
I am getting the same think on my edit 1 system with MC 8.10. Although not on my laptop system (edit 3 in specs). I suspect the Nvidia Driver, which in both cases is version 377.11.
I am in process of upgrading edit 1 to MC 2018.3, but having read your post I suspect it won't fix the problem.
Matt B
Window 10 would probably be better but everything was fine until the upgrade. I hope to touch base with Avid Support Monday but curiousy what is an edit 1 system?
I have three editing computers; I call them edit 1, edit 2 and edit 3. 🙂
Avid support had the answer and it was first the graphics card latest update 385.08 and then the settings. They said it should be:
Can you try this next: Go to the NVIDIA Control Panel (by right clicking on desktop): - Under Manage 3D settings > Global Settings > Use Base Profile and select Prefer Maximum Performance for the Power Management Mode - On the Program Settings tab > Select Avid Media Composer > CUDA - GPUs, select "Use These GPUs" and then check Quadro K2000D - Open GL Rendering GPU > Quadro K2000D - Power management mode > Prefer maximum performance - Threaded optimization > on - Triple buffering > on - Vertical sync > on Then launch Media Composer and check.
Thanks Ronald - I will try these settings out on my current driver (v377.11), I tried to update to 385.08 already but got an error that my card was not compatible, it is a Quadro 4000, presumeably too old!
Don't forget to enable Desktop Composition in Windows (with newer MC versions)
I can see a lot of "crashes" related to incorrect settings.
http://avid.force.com/pkb/articles/en_US/How_To/Enable-Desktop-Composition-in-Windows
http://www.freddylinks.com <-- Find EVERYTHING Avid and Tutorials there. Probably the most comprehensive Avid only webpage with over 2000+ Links to Avid Video Tutorials and Avid Information for Media Composer, NewsCutter, Symphony, Interplay, ISIS, Unity MediaNetwork, ProTools, Avid Artist Series. Completely free of fees, registrations, and ads.
I am now using Premiere more and more just too many tech support calls, not enough work getting done.
Hi Ronald,
these settings helped me with the same problem, thanks for sharing :)
I gave up on Avid I do Premiere only now. However I saw I had a weak solid states drive that was affecting the processor maybe it was the C drive and it's solid state.
