Latest post Sat, Mar 10 2018 8:03 PM by Cagey. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Mar 1 2018 8:27 AM
    System sound card audio with Decklink Mini Monitor
    does anybody know a solution for using the BlackmagicDesign Decklink Mini Monitor Card with System Sound Card Audio instead of embedded Audio? I Cannot find this setting in the Decklink settings...
    Thanks!
    Michael
    MC 19.07, WIN 10 x64, HP z840, dual E5-2640v3 2.6Ghz, 8x4GB RAM, Nvidia Quadro M4000, MXO2 LE, Artist Mix [view my complete system specs]
  • Thu, Mar 1 2018 9:40 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 281
    • Points 3,000
    Re: System sound card audio with Decklink Mini Monitor
    Same issue here , i Go hdmi into an external monitor and use a hdmi audio extractor to solve this.
    It's hdmi in , rca Audio out and hdmi video out.
  • Thu, Mar 1 2018 12:56 PM In reply to
    Thanks Martin, that seems to be a solution! Is the audio still in sync then? And can you affact the sync of the embedded audio with the desktop play delay setting? (sorry, I know I can try this on my own :-))
    Michael
  • Sat, Mar 3 2018 7:20 PM In reply to
    • fdooman
    • LOS ANGELES
    • Posts 550
    • Points 6,700
    I use Black magic converter SDI to HDMI, from SDI on the card to to BM. and then into mixer to get the audio. works great in this end.
    Symphony 6.0 on PC MC 6 on MAC Pro 3.2 GHZ 2008 model, 8 Gig of ram, Nvidia 8800 GT video card. 500 Gig system drive, 320 gig extra drive, Cineraid 2TB... [view my complete system specs]
  • Sun, Mar 4 2018 11:04 PM In reply to
    • Martin Fox
    • Sydney Australia
    • Posts 281
    • Points 3,000
    On my set up,everything was in sync. I suppose it depends on the process speed of the hdmi monitor. I would imagine the audio play delay doesn’t work and that the audio is packaged up in the hdmi signal. But I have not tried it, I’ll see if I can report back.
    the first monitor I tried this with first was a Dell ultra sharp which would output the hdmi audio from it headphone socket.
  • Sat, Mar 10 2018 8:03 PM In reply to
    • Cagey
    • Vista, CA
    • Posts 319
    • Points 4,120
    I'm using the Decklink MM 4K connected via SDI cable to MM SDI to HDMI 6G which is connected via HDMI to my 4K monitor and via balanced cables to my speakers. Everything is in sync. This setup avoids the sync issue resulting from different paths for audio and video signals.
    So far so good.
    kg
    MC8.6.1, Z420 Xeon E5-2670, 32GB RAM, GeForce GTX 1080, DIGI002, Win 10 Pro 64-bit [view my complete system specs]
    There are 10 kinds of people in the world, those that get binary, and those that don't.
