Latest post Sun, Aug 7 2022 11:46 PM by Jonno Woodford-Robinson. 14 replies.
Page 1 of 1 (15 items)
  • Fri, Nov 10 2017 5:50 PM
    • SR555
    • Joined on Mon, Oct 28 2013
    • Posts 219
    • Points 2,475
    Shortcut to switch between tabbed bins?
    I know you can switch TO the bin window with Cmd-~.   And in the project window, you can Page Up-Page down between the tabs.
    But if the bins are tabbed in a regular bin window, is there a simliar shortcut to switch through them?
    If I could save the individual windows in a stack and have it hold the bin position, I could cycle between them with Cmd~.  But it's a hassle, and the bin layout for some reason won't save between my two monitors, so it's necessary to drag them over and re-stack them each day when I come back to this particular desk and hook it up.   In short, it's inconvenient, not to mention messy.   And my bins are changing all the time in this project, so saving specific bin layouts isn't really practical.
    Surely there must be a very simple solution to switch between tabs without mousing?  Has anyone found a working solution for this?
    Thank you
    Avid Media Composer 7, Macbook Pro Retina, Mountain Lion [view my complete system specs]
  • Thu, Jan 11 2018 6:59 PM In reply to
    • David Parke
    • Joined on Tue, Dec 6 2011
    • Los Angeles
    • Posts 30
    • Points 340
    Re: Shortcut to switch between tabbed bins?
    BUMP. Looking for this exact short cut, too!
    MC 2020.8.0 | macOS Catalina 10.15.7 (19H512) | 27" iMac 2020 3.8 GHz 8-core i7 | 40GB RAM | AMD Radeon Pro 5500 XT 8 GB | Archion shared storage [view my complete system specs]
  • Tue, May 1 2018 7:18 AM In reply to
    BUMP AGAIN! Looking for this too.
    Media Composer 8.8.4 | iMac (Retina 5K, 27-inch, 2017) 4.2 GHz Intel Core i7 | 64GB Ram | OSX 10.12.5 [view my complete system specs]
  • Sat, Jun 29 2019 11:52 PM In reply to
    • Zach Fine
    • Joined on Thu, Mar 31 2011
    • Posts 45
    • Points 505
    BUMP! Yes would like this.
    It'd be very useful for optimum efficiency if the user didn't have to take their hands off the keyboard to do simple navigation tasks (and would also be great for automation).
    Media Composer 2021.3 OS X 11.2.3 Late 2013 MacPro 3GHz 8-Core 128Gb RAM D700 GPU [view my complete system specs]
  • Sun, Jun 30 2019 1:55 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,911
    • Points 50,005
      Moderator: MCA Mac
    There's something of a shortcut, but you still have to use a mouse. At the top right of the bin container, there is a down triangle. Clicking on that brings up the list of bins in a popup. You select the bin you want from there. You may have to experiment to see if there is a keyuboard equivalent.
    Dave S.
  • Mon, Jul 1 2019 4:24 AM In reply to
    http://community.avid.com/forums/p/197409/884039.aspx#884039
    A Tip for how to see and select bins, tabbed or not, using only keyboard, with no mousing. (Win version-2019.6 tested)
    -Telegram!
  • Thu, Dec 12 2019 6:04 PM In reply to
    If you float the panels or bins or windows, then Cmd~ will cycle betwixt them. Cmd~ will work on any windows that are floating and not docked. Just discovered this. You totally lose the docking feature, but I prefer being able to use Cmd~ over docking. I have everything floating, even individual bins so that I can tab from each to each with Cmd~.
    New Template
  • Sun, Mar 1 2020 12:04 AM In reply to
    Me too!!  Have been witing for this since it used to work back in a really early verison of tabbed bins (well, at least I think it did - it's been so long).
    Please please please make it a thing!!!
    And while i'm at it, Mute Clips is a binary tolggle function so why is it two separate keys?  switching tracks on and off are also binary toggles and they are just a single key which toggles on and then off.  Can Mute Clips also be made to do this so I don't waste two keeys of my already overflowing keyboard settings?!
    Jonno
    iMac (27", Late 2013, 3.5 GHz Intel Core i7, 32 GB, OS X Mojave 10.14.6) Connected to 27" Thunderbolt Display, BlackMagic UltraStudio Express... [view my complete system specs]
    www.fusspotfilms.com
  • Fri, Jul 29 2022 5:11 PM In reply to
    • ykt28403
    • Joined on Thu, Dec 22 2016
    • Los Angeles
    • Posts 116
    • Points 1,355
    BUMP!
    Media Composer 8.9.2Mac OS Mojave 10.14.6MacBook Pro 13-inch Early 20152.7 GHz Intel Core i58 GB 1867 MHz DDR3INtel Iris Graphics 6100 1536 MB [view my complete system specs]
  • Fri, Jul 29 2022 5:46 PM In reply to
    ykt28403:
    BUMP!
    No need.  This is in development.  it's coming very soon.
    Email me to create a support case: chris.bove@avid.com
    Chris Bové
    Avid Online Community Manager
  • Sat, Jul 30 2022 5:09 AM In reply to
    Yay!!
  • Fri, Aug 5 2022 6:36 PM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 211
    • Points 2,695
    Chris Bové:
    Switching tabs? Or a mute/unmute toggle? Because if it is the latter, I hope this is not going to replace but to complement the two existing functions.
  • Sun, Aug 7 2022 3:53 AM In reply to
    Jonno
    Cutyes:
    I'm pretty sure it's the former (Tabbed bin switching).
    But if it was the latter (Toggle Mute/Unmute), I imagine your concern is the ability to highlight a whole bunch of clips including both muted and unmuted and switch the muted ones on?  If that is the case, and Toggle does revert to a Binary Toggle, then all one would need to do is right click the timeline, Select>Muted Clips and then one would Toggle them back on again.  The only catch would be if you wanted to do that to a partial selection of the timeline, i guess, but maybe they could extend the Select Muted Clips 'between Marks on selected tracks' so that if there were no marks it would do the whole timeline, but with marks it would just do the area between marks that you wanted to be affected.
    In any case, I had actually made this Toggle thing in a separate thread which I think you might have commented on  : )
    But do mention if there's any other reasons I haven't thought of why the current version is preferred in your case - I can't say I can think of another reason...
  • Sun, Aug 7 2022 12:29 PM In reply to
    • Cutyes
    • Berlin
    • Posts 211
    • Points 2,695
    Yes, we had that conversation two years ago in the other thread. ;)
    - Apparently - correct me, if I am wrong - Select > Muted Clips cannot (yet) be mapped to the keyboard. Hence, more menu clicking, more time consuming.
    - Even if it was, it neither recognizes in/out nor selected tracks (yet), as you mentioned.
    - Even if it did, it would be at the expense of being able to just quickly drag-select the desired clips regardless of in/out or selected tracks.
    - To mute not-muted clips in a mixed selection you would have to also add Select > Reverse as an extra step.
    So, still, I see how toggle would be a very good enhancement - but not a replacement.
  • Sun, Aug 7 2022 11:46 PM In reply to
    I think you have a fair point.  Perhaps all Avid needs to do is add one extra button which is a toggle, and keep the other two buttons exactly as they are - then we can choose to either map a toggle that inverts Mute and Unmute, or map the two existing buttons for their current function.
    I might update the posts I made to the other Mute Clips Feature Requests that I found in my hunt yesterday : )
