Latest post Mon, Jun 19 2017 3:03 PM by BarkinMadd. 9 replies.
Page 1 of 1 (10 items)
  • Sun, Jun 18 2017 6:42 PM
    • dmfreeman
    • Michigan
    • Posts 1,867
    • Points 24,745
    m2t HDV 1440 X 1080 29.97 files How To Import
    As the subject header states, I have a number of digitized files in the above format that I would to link to a project.  Thus far I have not been able to do so.  Any ideas on how to accomplish this?
    Denny
    Media Composer 2019.6, BCC Continuum 12.5, , Boris Red 5.6., Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows 10 Pro 1803... [view my complete system specs]
  • Sun, Jun 18 2017 7:03 PM In reply to
    Re: m2t HDV 1440 X 1080 29.97 files How To Import
    What's the format/frame rate of the project, and what happens when you try to link to the footage?
    Media Composer 2022.12.2 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Sun, Jun 18 2017 7:29 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,867
    • Points 24,745
    Hi Carl,
    I set up an HD NTSC 1920X1080 29.97 project.  When I attempted to link via the source browser, the error was that the files could not be linked.  I have a hunch that the project creation is the issue here.  The m2t files are 1440X1080 29.97fps.  What do I need to do?
    Denny
  • Sun, Jun 18 2017 8:53 PM In reply to
    This one of VERY rare cases where the old "import" option is the way to go.  It won't link to raw HDV unless you purchase and install third-party software.
    HDV gets weird due to its non-square-pixel formatting, so bear with me...
    Before you start Avid, DISCONNECT any video I/O hardware if you're using any.
    Now, open MC and your project.  Go to the project settings window, and change the project raster to 1440x1080.  IMPORT the files - they should fast-import (you might also need to change to 1080i59.94 - I'm not sure, I forget).
    Now, you can exit the software, reconnect your hardware, change back to 1920x1080, and proceed.
    (SYSTEM 1) iMac Late 2012 27" (13,2), Mac OS X 10.15.6, Avid Media Composer 2020.12 w/Symphony, Intel Core i7 3.4 GHz, 32 GB RAM, NVIDIA GeForce GTX... [view my complete system specs]
  • Mon, Jun 19 2017 10:04 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,867
    • Points 24,745
    You were spot-on with your assessment.  The files did fast import without issue.  I left the project raster at 1920 X 1080 just as it was, the the issue is resolved.  I would have prefered linking and transcoding, but . . .
    Thanks so much,
    Denny
  • Mon, Jun 19 2017 12:15 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    dmfreeman:
    You can always transcode the fast imported media to a better codec , gives you better quality imho
    Tomas
  • Mon, Jun 19 2017 1:26 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,867
    • Points 24,745
    Hi Tomas,
    Thanks for the tip.   I will try that this evening and see if it makes a difference.
    Denny
  • Mon, Jun 19 2017 2:26 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    You´re welcome Denny , it´s about the same as when you capture tapes , SD or HDV , you almost never edit and render in that ( low ) quality .
    Tomas
  • Mon, Jun 19 2017 2:29 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Linking and transcoding would have made your workflow with m2t files the same as working with most of your other media files. This was the reason why I was looking for an AMA plugin for m2t. The good news is that the fast import of m2t just re-wraps the media so there is absolutely no generation loss. Once it's in, as Tomas mentions, you can transcode it to whatever you like to improve editing performance and to reduced subsequent generation loss, presumably.
    I would like to see if a batch import would work in the case where you trashed your imported m2t files and needed to re-import them - would it link correctly to existing master clips? Hopefully - I've never tested this but I will now that you've reminded me about this issue - lol
    Cheers
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Jun 19 2017 3:03 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    I just did a quick test and batch re-importing works very well in two ways - either clicking on the clips or on the sequence that contains the offline clips... The method of selecting the sequence actually generates new master clips - interesting but very workable).
    Steve
