We currently are having a few issue with PhraseFind v2
1. Can't figuare out how to get an upgrade to work. Purchased a PhraseFind v2.0 upgrade, and have my PhraseFind 1.0 activation box/code. But that's as far as it goes. Can't activate 1.0 on 8.8 and 2.0 gives me a "Prior product is not correct for this Upgrade Licenese" error. Also can't add 1.0 to my.avid account.
2. I have PhraseFind 2.0 activated on 2 other system. On both system PhraseFind finds nothing, reutrning zero results. Indexing lights are green but no results in 2 different projects. Both are Macs running 8.8, one is OS 11.12 the other is OS 11.11, connected to ISIS.
Please reach out to support for assistance.
Thanks!
Jackrabbit416: So we currently are having a few issue with PhraseFind 2 1. Can't figuare out how to get an upgrade to work. Purchased a PhraseFind 2.0 upgrade, and have my PhraseFind 1.0 activation box/code. But that's as far as it goes. Can't activate 1.0 on 8.8 and 2.0 gives me a "Prior product is not correct for this Upgrade Licenese" error. Also can't add 1.0 to my.avid account.
Standby I will create a case for this upgrade error.
RalphC
Here is the case PF upgrade 03154060.
Jackrabbit416:2. I have PhraseFind 2.0 activated on 2 other system. On both system PhraseFind finds nothing, reutrning zero results. Indexing lights are green but no results in 2 different projects. Both are Macs running 8.8, one is OS 11.12 the other is OS 11.11, connected to ISIS.
I entered separate case for the PF issue 03154074. Support team will investigate this.
Thanks Ralph, is there anything I need to do to get this cases linked to My.Avid support account. Not seeing them listed there.
I do have a case for the Phrase find not finding anything issue. Case Number 03153889
Jackrabbit416: Thanks Ralph, is there anything I need to do to get this cases linked to My.Avid support account. Not seeing them listed there. Thanks!
It should be listed now in the All Cases.
did you get a solution to the Phrase Find not finding anything? I'm experiencing the exact same thing on one of my systems (MCv8.8.2).
everything looks correct, but when you hit the Phrase Find button, nothing.
Unfortunately, we only have 1 version of the plugin so I cannot test things on another system AND the system it's on has a heavy deadline for the job he's on.
Any more news?
Joe Procopio Broadway Video AVID|DS Artist AVID Tech
Joe
You have a 1.0 to 2.0 upgrade to PF? can you email me the activation ID's for both 1.0 and 2.0 and your system ID.
marianna
