Subcap in this version seems to not accept either .stl or .txt (DS) files when trying to import.I saw that this was an issue in 8.6.3.Can anyone confirm if the problem was present in 8.5.3 or am I just having a bad day?Thanks,Jef
Jef Huey
Ok, I did some testing. I was able to open a .stl file on a MC 7.0.4 system just fine.
Same .stl file would not open on 8.5.3.
So, we are not going to go to the 8.7 area yet. What version is Subcap working other than that?
Jef
EDIT: I was wrong. A DS Text file does import into 8.4.5. Still need to get a working .stl file.
It also looks as if the same problem is present in 8.4.5!!
What versions DOES subcap work on might be a better question???
