Marianna: It shoud peace..... they are working on it for 8.8.2 Marianna
It shoud peace.....
Does that mean it didn't make it into 8.8.1? Well obviously I guess. I really think this is a showstopper and shouldn't be releasing new versions until it's addressed.
John
Mondo: Marianna: It shoud peace..... they are working on it for 8.8.2 Marianna Does that mean it didn't make it into 8.8.1? Well obviously I guess. I really think this is a showstopper and shouldn't be releasing new versions until it's addressed.
+1
Tomas
Unfortunately not as they havent completely fixed it yet and then there is testing.... 8.8.1 is out today so it should be in 8.8.2
Yes, I have gotten both the venetian blinds look and a green-tint (and/or magenta-tint) flash frame or series of tinted flash frames. I'm using XDCAM footage and it seems to happen near transitions. the venetian blind phenomenon seems to happen near effects when i'm fading titles/keyed graphics on and off.
How do I turn off GPU rendering?
Hoh
To remove that GPU rendering button and switch GPU render off . Render settings, check “Disable GPU effects”
marianna
marianna,
thanks for the quick reply and solid info!
as always, thanks!!
-darin
you got it! Happy to help!
Hi.
We just upgrade from MC 8.2 to 8.7.2. It was a lot of work (interplay, archive, transfers, ...). Now we face the same render issue as everybody does.
Please developpers don'l leave 8.7 without a patch. We cannot upgrade to 8.8 due to interplay version iintegration with third parties.
Thanks.
Typhon....
8.7.x and 8.8.x have the exact same Interplay support. There is no difference of Interplay support between 8.7.x and 8.8.x
I’m curious why you think 8.8.x is different from 8.7.x in this regard.
Can you elaborate?
Hi Marianna.
Thank you for giving me that precision. Indeed in the Interplay production Matrix i see that we can use MC 8.8 on our fresh interplay 3.5.
We are coming from 8.2.10 where we were stuck because of Inerplay 3.0.5. I had the reflex to link the MC version to Interplay..
We decided to install an already tested version (8.7.2) instead of using a too fresh 8.8. It is good to know that we can eventually install 8.8. But the What'sNew for 8.8 didn't bring interesting functionalities for us.
Sould i understand from your post that we should go to 8.8 and that there will be no patch for 8.7?
I will follow the release of the coming patches.
Hi there Typhon.....
Yes you can install and upgrade to 8.8.x and in fact we are hoping that 8.8.2 fixes this render issue.
You ask: Should i understand from your post that we should go to 8.8 and that there will be no patch for 8.7?
Answer: Correct - all patches will be for the 8.8.x code base.
Just adding our experience: We have several suites on 8.7 or 8.8 Mac and PC and are finding glitches in mixdowns, exports and even tape layoffs from all machines.
What's the lastest safe version?
david@cuttothebeat.com: Just adding our experience: We have several suites on 8.7 or 8.8 Mac and PC and are finding glitches in mixdowns, exports and even tape layoffs from all machines. What's the lastest safe version?
I´m doing all my productions on 8.65
I upgraded to 8.8.2 last week, but have had several single field "venetian blind" render errors since.
Did this fix make it into the update? If so, it looks like it's not solved it fully.
Not fixed yet , still on 8.65 for production jobs myself
