Latest post Sat, Oct 21 2017 1:21 AM by bannerman. 29 replies.
Page 2 of 2 (30 items) < Previous 1 2
  • Fri, May 12 2017 12:03 PM In reply to
    • Yuri
    • Joined on Thu, Jun 22 2006
    • Moscow
    • Posts 17
    • Points 255
    Re: MC 8.7 whith my dual screen configuration problem
    ALL, Please check 8.8.3 !!!!
    in my system second monitor already in work!!!
    but every  time, I must move bins etc. on it,
    but problem moved to next stage, I see.
    Sory for my english!
    p.s.
    I create new Workspace+New Binlayout & link its
    now
    start AvidMC ,
    resize main window to 2nd monitor
    and select its Workspace
    All good work!!
    Thank You very much, Avid!
    Asus_X99-E_WS i7-5960X 32Gb_DDR4 GTX750Ti GTX1070 BM_DecklinkHDExtreme3D+ Win10_1809,MediaComposer Subscribe 2019.12 [view my complete system specs]
  • Thu, Jul 6 2017 12:26 AM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 704
    • Points 8,035
    Freddy:
    So I would suggest using two monitors with same resolution for now.
    ..it might be something we will support in the future.
    i know, it's been only half a year, but...is there another answer now, giving a little hope?
    symphony 2020.12 - win 10 pro64 v.21H2 - nVidia gtx1080 OC (472.47 studio) - intel i7 6800k @4.2ghz water cooled by corsair H100i V2 - MSI X99A - 112GB... [view my complete system specs]
    • touviere7
    • los angeles
    • Posts 704
    • Points 8,035
    • touviere7
    • los angeles
    • Posts 704
    • Points 8,035
    • touviere7
    • los angeles
    • Posts 704
    • Points 8,035
  • Thu, Jul 6 2017 12:30 AM In reply to
    • touviere7
    • los angeles
    • Posts 704
    • Points 8,035
    sorry about the glitch....
    please can someone delete the duplicates...:-)
  • Tue, Aug 15 2017 4:13 PM In reply to
    • touviere7
    • los angeles
    • Posts 704
    • Points 8,035
    in another thread about mc 8.9,
    a comment from marianna makes me wonder if there is a change in the behavior with two monitors of different resolution...
    can we please have a comment on that?
     Marianna:
    Also, dual monitors must be set with same scaling regardless of the resolution of each monitor.  For example, if someone has 1920 x 1080 and 3840 x 2160 monitors connected to same system, they must set both to 200% (or 100%, 125%, 150%, etc).
  • Wed, Aug 16 2017 8:47 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,640
    Business as usual for Avid I see - ignore the user base and carry on regardless.
    John
  • Wed, Aug 16 2017 4:57 PM In reply to
    • Posts 11,593
    • Points 256,090
    Touviere
    I checked with Dave and this is the case as stated above with 8.9. There is work being done to get what is needed but it isnt completed yet. I will post as we get closer but I wouldnt thik it will be Q3
  • Wed, Aug 16 2017 4:59 PM In reply to
    • Posts 11,593
    • Points 256,090
    Mondo...
    Thats a unfair comment....  I take 2K emails a day and monitor ths location and facebook.  I get to each post, email, etc as quickyl as I can.... but even I am human!
  • Wed, Aug 16 2017 5:22 PM In reply to
    • touviere7
    • los angeles
    • Posts 704
    • Points 8,035
    mm
    thanks for your positive update Yes
  • Mon, Aug 21 2017 9:06 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,640
    Marianna:
    Mondo...
    Marianna - was not referring to you (not sure how I could have been?). You have always served the customer base and I've always held you in high regard.
    I was referring to a post by "Freddy" from Avid back in Dec 2016 that clearly states that users should just buy two monitors of the same resolution because this change is by design (I'm not quite sure what to do if I want to run three monitors?). I wouldn't even know if the problem's been solved. He's failed to pop back to the forum to update us since on this issue or whether he now considers it a problem. Apparently one post was all he had time for. He doesn't even bother to respond to Rodpaul's follow up post about it being an unsatisfactory answer.
    Avid is my favorite NLE but I don't use it any more - just hasn't kept up with the competition. I don't want to get this thread off track so I'll leave it there.
    John
  • Mon, Aug 21 2017 7:33 PM In reply to
    • Posts 11,593
    • Points 256,090
    MOndo....
    Pheew for a minute there :)  LOL
    The software to make 2 different size monitors work with the windows resizing is still in development ( already stated that).
    I agree that it took a while to get high res monitor support on PC's  (we logged that bug several years ago)!  This was low priority in the minds of Product management.   They are on it now based on all the chatter.
    Let me see what I can find out from them on it.
    marianna
  • Thu, Oct 19 2017 11:57 PM In reply to
    • touviere7
    • los angeles
    • Posts 704
    • Points 8,035
    maybe worthy to wake this threat up again...
    where are we standing?
  • Sat, Oct 21 2017 1:21 AM In reply to
    • bannerman
    • Canada
    • Posts 65
    • Points 840
    Yes, wake it up indeed. We need to keep the pressure on. I've been following this and waiting to update. Sure is fun to pay a monthly subscription for software I can't update because of this silly change. The explanation of losing bins is just annoying. We've managed for many years Avid. Don't need your 'help' now. Just get it working.
