Latest post Sat, Jul 9 2016 4:50 PM by usatraveler. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Jul 7 2016 1:26 AM
    • bitterjester
    • Joined on Mon, Jan 5 2009
    • Highland Park, IL
    • Posts 13
    • Points 165
    Transcoding - Keep frame rate versus Convert frame rate
    Hello,
    If I've filmed at 23.976 ProRes 422 and want to edit at 23.976 ProRes 422 is there any difference to using "Keep Source's Frame Rate" versus "Convert to Project Frame Rate." The only difference I see is a slight increase in used disc spac for the convert option.
    AVID 2020.6 Catalina 10.15.6 Model Name: MacBook Pro Processor Name: 8-Core Intel Core i9 Processor Speed: 2.4 GHz Number of Processors: 1 Total... [view my complete system specs]
  • Thu, Jul 7 2016 1:10 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,070
    • Points 49,100
    Re: Transcoding - Keep frame rate versus Convert frame rate
    Interesting.  I would have said there is no difference at all.  Is the size difference in the video files, audio files or both?  Does the metadata in the newly created master clips show any difference?
    Is one a consolidate and the other a transcode?
    Curious.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2021 iMac w Big Sur [view my complete system specs]
    Jef Huey
  • Thu, Jul 7 2016 4:11 PM In reply to
    • Greg Cohan
    • Joined on Thu, Apr 9 2015
    • Hollywood
    • Posts 95
    • Points 1,090
    I think what your seeing is a codec difference.  I could be wrong because I'm not in front of a system but but convert will give you DNX Codecs.  Keep will give you DNXHR codec.
    If you want to edit in Pro Res and your Master is Pro Res try Consolidating instead.  You shouldn't see any file size difference.
    60 Systems all running MC 2021.6 0n Catalina [view my complete system specs]
  • Sat, Jul 9 2016 1:55 PM In reply to
    • jef
    • Maryland
    • Posts 4,070
    • Points 49,100
    Greg Cohan:
    Could be.  A quick look at the codec info in the bin would confirm this.
    Greg Cohan:
    I had meant to suggest this as well.  Got lazy ...
    Jef
    Jef Huey
  • Sat, Jul 9 2016 2:32 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,474
    • Points 18,320
    In your case it doesn't make a big difference.  The main purpose seems to be when the source frame rates are mismatched it allows for relinking from a timeline to the mismatched footage.
  • Sat, Jul 9 2016 4:50 PM In reply to
    I've seen similar, even when the end result should be exactly the same - "KEEP" source rate at 23.976 ProRes, versus "CONVERT" rate also at 23.976 ProRes.  It should be identical, but somehow, Avid estimates that it won't be.  Still, it's very possible that after the conversion, it does turn out to be identical anyway.
    Regardless, as others have pointed out, ProRes can be consolidated.  Just do that instead.
    Generally, when you actually ARE working with footage that's a different rate (which is NOT the case here), keep in mind that when you convert to another framerate, you can no longer relink back to the original media.  For that reason, I always like to use that new option to keep the source rate.
    (SYSTEM 1) iMac Late 2012 27" (13,2), Mac OS X 10.15.6, Avid Media Composer 2020.12 w/Symphony, Intel Core i7 3.4 GHz, 32 GB RAM, NVIDIA GeForce GTX... [view my complete system specs]
